AVOturboworld
Old 02-12-2013, 03:27 PM   #2213
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by AVOturboworld View Post
Here's the specifics of our Stage 2.0, which we've decided will be 7.5 psi setup that retains stock fueling.
3-bar MAP Sensor
7psi Actuator, or Boost Controller and standard 5psi Actuator
2.5" Cross over pipe
2.5" Stainless Steel Front Pipe with 5" metal cat
Stage 2.0 Base Map Tune with 8psi Fuel Cut
Final tuning for this package will be done in early March, after which we'll release these packages.
We feel this is a good base for setups going to 8~14psi, in that all you need to add after that is fueling and tuning.
If we got fueling done at the same time would you raise the 8psi fuel cut?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-12-2013, 06:52 PM   #2214
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
When you get the kit, change fueling and get a custom tune at higher Boost. AVO provides a base map, they don't tune specific setups. The custom tuner will take care of you (I am getting my kit and right off the bat getting a custom tune to extract all the HP available for my weather conditions).
The Following User Says Thank You to Sportsguy83 For This Useful Post:
DriftEightSix (02-12-2013)
Old 02-13-2013, 03:15 PM   #2215
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
3-bar MAP Sensor
Would you be able to recommend fueling components to start looking for to cover 14psi?
I mean which cc rate should injectors be and which lph a fuel pump should to be on a safe side?
Would it be possible to include these fuel items in the package? ( personally I'm tempting against Deatschwerks 700cc's & Deatschwerks 265lph )
I ask this because I know, that different injector sizes need different fuel maps even for start-up.
I am going to have a Pro-tune ASA I put the kit on, but I think I will need your basemap to allow me to start the engine up and roll to the tune spot in some time.
Possible?
Mike
MSTiFK8R is offline   Reply With Quote
Old 02-13-2013, 09:07 PM   #2216
RC86
Drives: '14 Maybe
Sorry if this was already covered, but how much weight does the kit add to the car and what's the final weight distribution?
RC86 is offline   Reply With Quote
Old 02-13-2013, 09:28 PM   #2217
AVOturboworld
The AVO turbo, UEL manifold, and turbo discharge pipe as a unit weighs 29lbs - the stock exhaust manifold that those replace weighs 20.5lbs. After that, you are adding in the weight of the FMIC and it's silicone hoses. So we are talking about 8~9 lbs in the same location at the engine, then another 28~30lbs for the FMIC portion of the kit.
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
Apex Chase (02-14-2013), BRZranger (02-14-2013), cmss2000 (02-13-2013), sandman126 (02-14-2013)
Old 02-13-2013, 09:42 PM   #2218
RC86
Drives: '14 Maybe
Thanks for the info, that's not bad at all.
Old 02-14-2013, 03:15 AM   #2219
DriftEightSix
Pegasus White
Drives: 86
How large is the diameter?
Old 02-15-2013, 09:18 AM   #2220
dabocx
dabocx's Avatar
Drives: Scion FRS
Really looking forward what stage 2 does, i want to see how the top end holds up. Still 1400 for the stage 2 is not bad and it should be less for those already have a exhaust
dabocx is offline   Reply With Quote
Old 02-16-2013, 07:24 PM   #2221
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Any update on the high flow intake kit?
Tansey86 is offline   Reply With Quote
Old 02-17-2013, 04:34 PM   #2222
nix
nix's Avatar
Drives: AVO BRZ
We are going to use Visconti's SPD pump and his ~500cc short barrel injectors as well as an omni sensor to make around 10-14 psi on e85. Should have results in the next fortnight for you guys.
nix is offline   Reply With Quote
The Following 8 Users Say Thank You to nix For This Useful Post:
cmss2000 (02-17-2013), dabocx (02-17-2013), DriftEightSix (02-18-2013), mact (02-17-2013), MSTiFK8R (02-19-2013), OjiGeorge (02-18-2013), Sportsguy83 (02-17-2013), Tansey86 (02-17-2013)
Old 02-17-2013, 10:09 PM   #2223
Blue86
Drives: Sonic Blue 86GT Manual
That will be quick!
Blue86 is offline   Reply With Quote
Old 02-18-2013, 05:56 AM   #2224
DriftEightSix
Pegasus White
Drives: 86
Can't wait for this result!
What size exhaust are you running?
Old 02-19-2013, 03:15 PM   #2225
Travers
Drives: Toyota 86, Black, MT
I'm curious - has anyone done any 0-100km/h testing with the AVO Stage 1 kit installed?
Travers is offline   Reply With Quote
Old 02-19-2013, 09:40 PM   #2226
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
is there any way to oil the turbo without the extra oil pump? cant one elect to use the cars oil pump pressure?
Huehuecoyotl is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
