Old 02-12-2013, 08:41 PM   #1
Mokiki
Drives: FR-S firestorm
Tire rumble noise
I took my car out during lunch today and had a fun ride, not abusing, but did make several sharp turns at the back road. No drifting stuff.
Then I heard the tire rumbling noise on my way home after work. It first felt like flat tire, so I pulled over and checked, but all tires are fine. I can sometime feel the rumble at low speed <20, and my break and gas padel shakes too.
It's hard to capture the noise/rumble given how loud the car is, but once a while I can clearly feel the tire rumble, feels like those shopping cart had chewing gum stuck on one of the wheels, it goes pop pop. And I did check, there is no chewing gum on my tire.
I am going to try service dept this weekend, but u know those service guys, they will claim nothing is wrong. Has anyone experience the similar issue with scion frs?
Mokiki is offline   Reply With Quote
Old 02-12-2013, 09:14 PM   #2
Foobar
SLO NO MO
Foobar's Avatar
Rocks stuck in the tread maybe? Or something stuck between disc and brake pad?
Old 02-12-2013, 09:18 PM   #3
Mokiki
I did check tires, and they are clean. How do I check break and discs?
Old 02-12-2013, 09:38 PM   #4
White64Goat
Check all the lug nuts?
Old 02-12-2013, 09:54 PM   #5
Mokiki
Sorry, I'm not that handy with cars, what those lug nuts to do with the noise?
Old 02-12-2013, 10:08 PM   #6
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
If they're loose, you'll get more than a rumble, but it's worth making sure everything's secure.
Have you had any work done that might involve removing the wheels? Like a tire rotation? Anything else?
CircuitJerk is offline   Reply With Quote
Old 02-12-2013, 10:28 PM   #7
Mokiki
nothing has been done :-(, it only has 1400 miles on it. car drives fine during the lunch run. Then I parked the car, went back to work. It happened after I got off work, started rumbling the moment my car reached 10 mile/hr
Old 02-12-2013, 10:37 PM   #8
CircuitJerk
Pull my finger...
I'd get that looked at, asap.
Old 02-12-2013, 11:28 PM   #9
CaptainSlow
CaptainSlow's Avatar
Yeah, it does almost sound like a loose rim, although I have no clue how that would have happened (unless you have an asshole around you who is loosening up wheels). I had this happen one time (different car) and it sounded just like a flat tire. Hopefully it's something simple, but in the meantime I'd find the lug wrench and at least make sure it's not the lug nuts (since that could turn into something really bad really quickly.
For reference, these are lugnuts (the 5 nuts surrounding the Scion logo in a star pattern):
and you should be able to find a toolkit with one of these in it:
(not exactly sure what the FRS one looks like, but it should be somewhat similar to that)
If you can tighten any of those lug nuts AT ALL with that wrench, it was loose.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
CircuitJerk (02-13-2013)
Old 02-13-2013, 04:17 AM   #10
Gavin Albright
Drives: Scion FRS Whiteout
Before you do anything do like the other guys said and check your lugs
If that does not solve the problem there are a few other things I could suggest but sense you are not handy with cars the best thing you could do is bring it to someone who is.
Gavin Albright is offline   Reply With Quote
Old 02-13-2013, 04:22 AM   #11
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
You live in Pennsylvania, you have snow. Remove all the snow from the inside of your rims, they are throwing the balance off of your car. You should be fine after you clean them off. Otherwise, take some pictures, it will help us out.
LeeMaster is offline   Reply With Quote
Old 02-13-2013, 02:05 PM   #12
Big-B
Drives: 2013 Scion FR-S Ultramarine
Yeah, I was going to say a wheel weight may have come off, but your probably right.
It reminds me of "My Cousin Vinny" when the guy told him "you got mud in your tires".
Big-B is offline   Reply With Quote
Old 02-13-2013, 04:24 PM   #13
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You don't need to stand on the wrench or use your whole body weight to tighten them, over torquing (tightening) is almost as bad as having a couple loose.
I don't have the manual with me but 70-80 ft. lbs. should be more than adequate and easy to overdo even with a wrench like that if you are of average size and fitness.
Old 02-13-2013, 04:59 PM   #14
Mokiki
thank you all for the suggestions. I found the source is caused by this lil sucker. I checked all tires again in the morning when I can see them clearly, and found it stuck into my tire.
The Following User Says Thank You to Mokiki For This Useful Post:
CaptainSlow (02-13-2013)
How to get that boxer rumble? ryude Engine, Exhaust, Transmission 45 03-20-2014 03:30 PM
Tire Noise? Admiral Ballsy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 07-04-2013 10:02 PM
Borla headers! Get the boxer rumble! Esoteric Engine, Exhaust, Bolt-Ons 45 01-29-2013 06:47 PM
subaru rumble V1B Engine, Exhaust, Transmission 25 07-13-2012 08:03 AM
Rumble coming from rear end? No Quarter Scion FR-S / Toyota 86 GT86 General Forum 34 06-27-2012 03:14 PM
