Old 01-14-2013, 09:37 PM   #127
OrbitalEllipses
Drives: Attitude
For those between Brembos (which move bias forward) and FHI 4 pots (no added heat mass) there IS another option. KNS brakes is apparently working on a bracket to mount Nissan Z32 calipers (identical to FHI Subaru units, but cheaper and with Nissan mounting points) that will allow the use of Legacy GT rotors (316mm x 30mm) up front. There's a thread on NASIOC about this if you want to do more research.
Respect BRZ (02-14-2016)
Old 01-15-2013, 12:46 AM   #128
Z3D
Awesome thread guys. I really think aluminum knuckles would be very beneficial to a lot of BRZ/FRS drivers. I am guessing you could cut the sprung weight of the stock knuckle by at least half if not more. Also you would get a benefit of greater heat transfer from the brakes/bearings based on what type of aluminum is used. Oh and also easier to press hub bearings in and out.
Z3D is offline   Reply With Quote
Old 01-15-2013, 11:49 AM   #129
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by omegared19 View Post
Any recommendations on how to heat them up? I don't want to sit there like an idiot with my girlfriend's hair dryer for forever and not get them hot enough. I do have a heat gun, but don't want to strip the paint/STi logo.
I was originally going to use heat on mine, but I didn't want to ruin the finish on the caliper. The plugs are put in with red loctite which is why the heat might be required. I can't believe that I got lucky enough to get all the plugs out with no heat and no issues. Your best bet is going to be a small nozzle propane torch that you can get the heat right on the bolt head. I took my plugs out after I had already mounted the calipers.
Old 01-15-2013, 03:39 PM   #130
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
I've got a heat gun that I picked up a while back for doing tail lights. So I'm going to try that.
omegared19 is offline   Reply With Quote
Old 01-15-2013, 03:47 PM   #131
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No way a heat gun is going to get those threads hot enough to mess with the red loctite.
http://www.henkelna.com/industrial/r...ngth-12892.htm
Optimum temperature range is -65ºF to 550ºF
Disassembling requires localized heat (>550°F/260°C), hand tools, and disassembly while hot
Old 01-15-2013, 03:48 PM   #132
omegared19
omegared19's Avatar
What about a lighter? I found a bic in the parking lot the other day?
Old 01-15-2013, 04:15 PM   #133
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
Would any of you that have done the swap be able to measure the distance from front of the rotor hat or rotor to the end of the caliper towards the wheel spokes. Just to see how much is needed to fit the front calipers?
My prodrives have about 25mm more clearance than the stock wheels. Im wondering if that is going to be enough.
fenixv8 is offline   Reply With Quote
Old 01-15-2013, 04:23 PM   #134
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I will try to measure it tonight.
fenixv8 (01-15-2013)
Old 01-15-2013, 04:42 PM   #135
omegared19
omegared19's Avatar
And just so I/we're clear, the factory wheels will not work with the STi brake set up.
Old 01-15-2013, 05:09 PM   #136
fenixv8
fenixv8's Avatar
Yea won't fit. Spoke design isn't the best for this type of brake and prob need a more aggressive offset.
Big Spacer
Old 01-15-2013, 05:10 PM   #137
fenixv8
fenixv8's Avatar
Thanks King Tut
Old 01-15-2013, 05:10 PM   #138
omegared19
omegared19's Avatar
Then I guess I'm going back to getting 18's.......it'll be a fun upgrade anyways
Old 01-15-2013, 06:39 PM   #139
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
By default that doesn't mean you'll be fine..
17s work, but you need to find wheels that specifically fit a 2004 STi.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 01-15-2013, 06:45 PM   #140
omegared19
omegared19's Avatar
I'm eyeing a set of Advans.....I'm pretty sure they'll work. Just a guess tho
brakes, caliper, sti, swap
STI front brakes on BRZ (confirm) michael317 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 123 05-23-2016 01:41 PM
GTS Front Brakes + Rotors + Pads GC GTS Aero Kit Australia Classifieds 2 11-16-2012 06:20 AM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 11:08 AM
