Old 01-13-2013, 11:46 AM   #15
chate
Pharmasaurus Magnificus
chate's Avatar
Originally Posted by gmookher View Post
any time you play be ready to pay
So true, hopefully it's not too expensive OP!! Maybe consider 3rd party/independent shops too at this point since it'll likely be out of pocket cost
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85
2015 Nissan GTR
chate is offline   Reply With Quote
Old 01-13-2013, 11:58 AM   #16
2forme
LOL @ people calling that fraud, as if they wouldn't do the same....
That sucks man. I've had my pulley on for 4000 miles and have had no issues. Try checking the balance of the Perrin pulley, they could have gotten a bad stock of aluminum.
The Following 6 Users Say Thank You to 2forme For This Useful Post:
636 (01-13-2013), fuddbutter (01-17-2013), Gixxersixxerman (01-13-2013), LeeMaster (01-13-2013), TouchMyHonda (01-13-2013), Xanatos (01-13-2013)
Old 01-13-2013, 12:47 PM   #17
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Originally Posted by Hops Normal View Post
So I installed my perrin pulley today just like the DIY on here said. Then I got in my car and drove it for a minute. I got out of the car to let my buddy drive it and we hear a small knocking noise. We went back to the house and found that oil had exploded all over the engine bay. When we tryed to find the problem we had no luck all I know is the pulley wobbles before u start it. I have uninstalled the pulley and put the stock one back on and it does the sake thing. Any ideas? I need help.
Sent from my SPH-L710 using Tapatalk 2
This same thing happened to me, but I caught it immediately and was able to fix it before I had any issues. Did the billet seat for the pulley come out when you removed the stock pulley? If so, there is a keyway on the inside of that piece that is meant to line up with a key in the housing. I think its for the oil pump, but don't quote me on that. It's a bitch to reseat correctly. I had to shave out the corners of the keyway to let it slip in. It takes time, so be very patient.
I hope there's no permanent damage to your engine, but prepare for the worst. My advice for you now is to try to seat it correctly and install the stock pulley. Then return everything else you may have changed back to stock. Then tow it to the dealership and get it fixed hopefully under warranty.
My future advice is to always check your work before you drive away. If it doesn't look right, cut the power and fix it before trying it again. I hope everything is ok. Good luck.
thejevans is offline   Reply With Quote
Old 01-13-2013, 01:10 PM   #18
636
636's Avatar
Drives: '23 CWP BRZ
Keep us updated!
636 is offline   Reply With Quote
Old 01-13-2013, 01:31 PM   #19
White64Goat
I believe he stated that he put the stock pulley back on and it also wobbled. Oil seal would not cause wobble on a crank pulley to my knowledge. Would cause oil leak...........I think I would look for a reputable shop that services Subaru's in your area first for a diagnosis before the dealer. (One that has a small boroscope). Hopefully you have not damaged the key-way slot in the end of the crankshaft, which would not be good.
Old 01-13-2013, 02:11 PM   #20
Hops Normal
Hops Normal's Avatar
Drives: 2013 Scion FR-S Peral White
Ya o think it might be then same thing that happened to you. When I pulled out the billet seat the second time there's a small indent where I don't think it was lined up when I put the new pulley on. I have a friend that is really good with stuff like this and he's going to look at it tomorrow. I'm hopping its just a seal.
Sent from my Nexus 7 using Tapatalk 2
Hops Normal is offline   Reply With Quote
Old 01-13-2013, 02:21 PM   #21
Julio86
Julio86's Avatar
Drives: 2013 Scion FR-S 6MT
So I installed my perrin pulley today just like the DIY on here said. Then I drove it for a minute. I got out of the car to let my buddy drive it and we hear a small knocking noise. We went back to the house and found that oil had exploded all over the engine bay. When we tryed to find the problem we had no luck all I know is the pulley wobbles before u start it...
This is what I'm afraid of with the I stall of this pulley. Idk if I should do it myself :/
Good luck on getting this fixed and keep us posted on your findings.
I don't always drift every corner, but when I do, I drift FRS . Stay drifty my friends
2013 Scion FRS Whiteout 6MT
Julio86 is offline   Reply With Quote
Old 01-13-2013, 03:28 PM   #22
Celica00
Celica00's Avatar
Drives: 86
That's fraud.
yes, fraud is illegal. like i mentioned in my post.
Celica00 is offline   Reply With Quote
Old 01-13-2013, 06:18 PM   #23
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
Ethics, how do they work?
TheRipler is offline   Reply With Quote
Old 01-13-2013, 06:21 PM   #24
2forme
They work like this....
"Do I want to spend five grand on a new motor? No."
I'm not condoning it, but if all most people have to do to save five grand is swap a pulley....
Old 01-13-2013, 06:24 PM   #25
Mo707
Mo707's Avatar
The same thing happened with mine(the wabble part not the oil) make sure the pulley is parallel to the engine when you torque it. We used a pry bar to keep it straight. And watch it when you put it on before you start driving it.
Mo707 is offline   Reply With Quote
The Following User Says Thank You to Mo707 For This Useful Post:
milko002 (01-23-2013)
Old 01-13-2013, 06:50 PM   #26
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
That's Economics not Ethics.
kmbkk is offline   Reply With Quote
Old 01-13-2013, 07:03 PM   #27
2forme
Oh sorry, let me rephrase.
"Should I rip the dealer off because I don't want to spend 5 grand? Well, they rip more people off on trade-ins, so I guess it's ok."
Better?
Old 01-13-2013, 07:18 PM   #28
FirestormFRS
Directly behind the crank pulley is the front oil seal. Inside said seal there may be a small spring. The spring may have unseated from inside the seal. That would leave it hanging on the nose of the crank. When you put the pulley back on and tighten it the spring will only be between the top of the pulley and the stop on the crank. The wobble comes from the spring. The leak is also caused by the spring not being in the seal.
FirestormFRS is offline   Reply With Quote
The Following User Says Thank You to FirestormFRS For This Useful Post:
whataboutbob (01-13-2013)
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Perrin pulley instalation for AT help Teknian_Culprate13 Engine, Exhaust, Transmission 7 01-21-2013 11:43 PM
Perrin Pulley ArKiTeCkT Issues | Warranty | Recalls / TSB 12 11-06-2012 11:57 AM
Pulley install issue Boxer-86 Engine, Exhaust, Transmission 9 10-21-2012 07:37 PM
Camshaft Bolt Coming Loose After Perrin Pulley Install WhiteBRZ Engine, Exhaust, Transmission 25 09-20-2012 08:07 AM
