Old 01-08-2013, 03:09 PM   #1
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Size & spec of TRD wheels?
Sorry if this has already been asked, but does anybody know the width and offsets on these 18" TRD wheels? I recall they were just 7.5 inches wide and costs close to $1k each. I want to upgrade over the stock wheels and figured TRD should be the default reference point for wheel size and tire specs. Does anybody know if they're just re-badged versions of some other type of wheels?
mit_peid is offline   Reply With Quote
Old 01-08-2013, 05:09 PM   #2
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
i believe they where 18x7.5 +35 on 225/40-18
GT86drifter is offline   Reply With Quote
Old 01-09-2013, 01:51 PM   #3
mit_peid
Boosted Noob
mit_peid's Avatar
That sounds like what I remember seeing too. Seems like a lot of people who are taking tracking serious are going with 17x9 wheels and TRD decided on 18x7.5. Just seems kinda funny so many people are choosing to go with 18x9+in wheels deviating from years of Toyobaru R&D and people who track the car. Is it primarily people just want that wide tire stance look from behind? /rhetoric
Old 01-09-2013, 01:58 PM   #4
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
How about similar wheels for less? Love the 10 spoke, evenly spaced, black wheel look on this car.
KaliKev is offline   Reply With Quote
Old 01-09-2013, 02:24 PM   #5
mit_peid
Boosted Noob
mit_peid's Avatar
The black rims look sweet but I feel the bright red brakes also add quite a bit to the overall TRD look.
Old 01-09-2013, 02:26 PM   #6
ayau
Drives: Some rust bucket
I can think of a couple reasons why TRD and STI chose those wheel specs.
1. 18" to fit a big brake kit. Some 17" will fit a BBK, but it will depend on the design of the wheel. It makes more financial sense to produce a wheel that will fit all aftermarket big brake kits than only certain ones with a 17" wheel. For example, if you know you want to run 215 wide tires, then you can get rims that are 7"-8" wide. The wider the wheel, the stiffer the sidewall, but that will also increase the weight of the wheel/tire package.
2. 7.5" wide to keep weight and cost down. A 18x9 cast made wheel may weigh more than the OEM wheels. In terms of performance upgrades, you want to reduce the weight, not increase it.
There really isn't a "perfect" wheel size when you take into account cost. If everything else is equal, you want lighter and wider wheels to accommodate for wider tires. I think the tire size should dictate the wheel size IMO. For example, if you want to run 215 wide tires, then you can choose between 7"-8" wide wheels. Fitting wider wheels will increase tire sidewall stiffness but increase weight.
However, in general, you can't go wrong with TRD recommended sized wheels.
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 11:25 PM
Square Size Tires and Stagered Wheels BigJyoungblood Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-23-2012 08:44 AM
FS [WA] 17" GTS wheels with Tyres x 4 - get a full size spare Z86 Australia Classifieds 3 10-17-2012 05:24 AM
What size wheels do you plan on running? poormans_LFA Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 04-28-2012 06:30 PM
