| DIY (Do-It-Yourself) Guides For all DIYs. |
Waited 5 years for this
Drives: '18 MX-5 Club
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely
1) warm up the engine fully.
2) turn off the engine. 3) the side brake needs to be released. 4) press and hold the brake and start the engine. 5) while holding the brake, pull the side brake and let go of the brake. 6) press the brake 2 or more times and hold the brake. 7) while holding the brake, release and pull the side brake 2 or more times and hold the side brake. 8) while holding the side brake, press the brake 2 times. 9) TC and VSC lights should turn on. If you can't turn the TC and VSC back on by pressing the buttons, then it worked. You'll need to turn off the engine to turn TC and VSC back on. Note: I only tried this on MT. I'm not sure if it works on AT. |
| The Following 13 Users Say Thank You to Sigh-on-Rice For This Useful Post: |
#2 |
Drives: 2006 Pontiac GTO
Good god...that seems like a lot to do. Isnt there a button you can turn off and leave off?
#3 |
It looks like a lot. But if you memorize it, it only takes like 5 secs. Its like brake, brake, side, side, brake, brake. And holding on that button for 3 secs doesn't turn them off 100% completely.
#4 |
Drives: BRZ Limited
Actually, it is stupid simple. If I can do it anyone can. As you said it doesn't work when the car is cold, must be to temperature. How did you figure this out? How do you know it completely disables everything? Is it putting the car into maintenance mode?
#5 |
Drives: Asphalt FR-S
Does it stay off after restarting the car? Otherwise you don't need to do all this for the same result.
Edit- OK, just saw the post in the racing section where it is explained further driver aids are turned off by this procedure beyond just VSC and launch control. Good to know for track days.
Asphalt FR-S
1965 Mustang Vintage Road Racer Ducati Paul Smart 1000LE Ducati 848 Last edited by bpracer; 01-03-2013 at 12:42 AM. |
#6 |
Drives: WRB BRZ
This like putting some cars in launch mode. I guess Toyota/Subaru didn't want everyone to turn it off completely. There would be a lot more cars showing up on the junkyard.
In the garage:
1988 BMW E30 M3 2003 Ducati ST4s ABS 2006 Subaru Legacy GT Spec B #444/500 (For Sale) 2013 Subaru BRZ WRB Limited - Acquired 9/15/12 |
#7 |
I saw a post on how to do this in a forum for 86 in official Japanese Toyota site. And yes, it's in maintenance mode.
| The Following User Says Thank You to Sigh-on-Rice For This Useful Post: | developer (01-03-2013) |
#8 | |
#9 |
Drives: SUBARWD
Ok, so that's up up down down left right left right b a start?
| The Following 29 Users Say Thank You to I<3Twisties For This Useful Post: | 20valvewynn83 (07-09-2013), ATL BRZ (01-04-2013), B L U E S L A T E (01-09-2013), Bonburner (02-01-2013), BoostinIX (01-11-2013), Calum (01-04-2013), Dadhawk (02-01-2013), Deepseadiver (03-04-2013), demonpoofball (09-23-2014), g0lden (01-05-2013), gonzo (01-04-2013), Guff (01-15-2013), hippari (01-04-2013), hmong337 (07-03-2013), IBill4You (04-10-2015), IloveBaldEagles (01-21-2013), jazztennor (06-14-2013), Kwaziekeller (02-02-2013), lazyluka (01-13-2013), lbroskee (01-06-2013), ragingSPAM (10-06-2014), raul (01-04-2013), Retro86 (02-06-2013), SkAsphalt (01-07-2013), Snozzberries (01-06-2013), Tagera (11-13-2013), TheGuyWithTheFireStorm (01-05-2013), travace (01-06-2013), wparsons (01-03-2013) |
#11 |
Drives: BRZ Limited arrived on 9/1/2012
I saw a video on you tube they remove the fuse from the fuse box. That is for sure.
#12 |
Drives: 86
you can do it on easy way. only press TS bottom for 5 sec and it disconnected the system
| The Following User Says Thank You to aagun For This Useful Post: | Trashed675 (01-23-2013) |
#13 |
Site Moderator
Drives: Stuff
This "pedal dance" method which has been posted here a number of times now actually puts the car into a diagnostic mode. In this mode, it disabled the Electronic Brakeforce Distribution and "panic brake" functions as well. So technically holding the TCS button down and the "pedal dance" perform some of the same functions, but they aren't identical.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following 3 Users Say Thank You to Dave-ROR For This Useful Post: |
| TPMS, LSD and Stability Control | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 11-05-2012 05:12 PM |
| So, when does the traction/stability control work against you? | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 10-03-2012 10:06 AM |
| CEL Traction Control ON then OFF | HATED1 | Issues | Warranty | Recalls / TSB | 5 | 09-24-2012 08:11 PM |
| Traction Control / Vehicle Stability VSC kicking in when not necessary? | WTF | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-15-2012 05:24 PM |
| Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely | BabyGodzillaGTi-R | BRZ First-Gen (2012+) — General Topics | 40 | 04-25-2012 12:20 PM |
