Old 12-07-2012, 03:15 PM   #113
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Originally Posted by gmookher View Post
I'm gonna open a driving school for this forum...
lol I'll come help you.
Ranatsu is offline   Reply With Quote
Old 12-07-2012, 07:13 PM   #114
sierra
Drives: Skoda Yeti DSG diesel 4x4
Personally, I find 5th and 6th to be VERY notchy. 6th actually offers a lot of physical resistance that I actually need to shove it into gear especially over 3.5K RPM; I'm actually concerned.
Have you checked the oil level?
sierra is offline   Reply With Quote
Old 12-07-2012, 07:22 PM   #115
OrbitalEllipses
Drives: Attitude
Nope, it's cold and I don't feel like getting underneath there to undo the fill bolt. I don't even have ACTUAL level surfaces near me either. I guess I'm gonna go bug a dealer.
Old 12-08-2012, 10:45 PM   #116
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
How easy is it for everyone to downshift into 5th gear? I always encounter some resistance doing so; it never goes in as easily as downshifting to 2nd-4th gear.
Subie is offline   Reply With Quote
Old 12-11-2012, 01:01 AM   #117
moK
Drives: White BRZ
Every time I up or downshift into 2nd, there is a very audible thunk and mechanical feeling in the shifter, but no grinding. I also have to let off the clutch slower than all the other gears or it'll be a very jerky shift, and this happens whether the car is cold or warm. Every other gear is fine
moK is offline   Reply With Quote
The Following User Says Thank You to moK For This Useful Post:
LeeMaster (12-30-2012)
Old 12-11-2012, 03:47 AM   #118
sierra
The same would be true of 1st gear but even more so. The lower gear ratios receive higher loads from the engine.
Old 12-11-2012, 09:34 AM   #119
Bluetib
Subaru product specialist
Bluetib's Avatar
Drives: BRZ Sportech
Trans flush to Pentosin MTF-2 is the solution, it's like
butter even in the coldest weather (Montreal)
Feels like a diiferent transmission now, smooth with
no restrictions at all.
Bluetib is offline   Reply With Quote
The Following User Says Thank You to Bluetib For This Useful Post:
Cameronghanson (12-30-2012)
Old 12-11-2012, 06:52 PM   #120
Gitsum3x
Gitsum3x's Avatar
Drives: 2013 Scion FR-S 6-speed whiteout
Transmission syncros
I've been having the same problem with my first and second gears too. Bought my fr-s about a month ago. It has about 800 miles on it and it is definitely something wrong. Mine seems to be particularly bad on first drive, when car is cold and has been sitting. Has anyone took their's to the dealership to get it checked out?
Gitsum3x is offline   Reply With Quote
Old 12-30-2012, 03:14 AM   #121
sierra
It's going to feel a bit tight when the oil is stone cold but it soon warms up.
Change the oil for Pentosin MTF-2 as suggested, I will on mine when the weather cools down.
Just for the record. I picked up my GTS86 manual on Xmas Eve and have clocked just over 1000km.
I can snick it into 1st gear while it's moving without any problems at 20kph. No double clutching to rev match, just shove it from 2nd into 1st and let the clutch out. There have been many posts saying you can't, shouldn't shift into 1st unless it's stationary and it's a load of old cobblers.
Old 12-30-2012, 11:29 PM   #122
Cameronghanson
Drives: n/a
i switched all my diff fluid and tranny fluid to redline and it fixed all of that. all of my BMWs and MINIs felt the exact same way until i switched out the fluids
Cameronghanson is offline   Reply With Quote
Old 12-30-2012, 11:58 PM   #123
sierra
I take it you used Redline MT-90 in the trans but what is the right stuff for the diff? I'm not sure we can get it here, i'll check.
Great! They sell it just up the road, 20km away.
3.78L of MT-90 is $168!
Old 12-31-2012, 07:58 AM   #124
roddy
roddy's Avatar
Drives: '13 Ultramarine
Holy crap that's expensive! You only need ~2.3L of that for the transmission. I used MT-90 in mine with good results until the temperature got below 40-50F (5-10C). Others have had better luck with the MT-85. For that money, see if you can find a supplier for Pentosin...really good stuff.
The preferred weight for the rear diff is 75W85. Here is a link to the proper weight Redline oil...
http://www.redlineoil.com/product.aspx?pid=40&pcid=4
75W85 is fairly common in the Toyota world, and may be in stock at your local Toyota dealer.
75W90 GL5 is also acceptable for the rear end, and may be easier to find.
Old 12-31-2012, 08:36 AM   #125
sierra
That's what I thought too. When you factor in the exchange rate it's about 3 x the US price. It's just imported in the US containers in quarts and gallons. Cheeky buggers!
I'll chase up the Pentosin on Wednesday. It should be in stock at the dealers.
Thanks for the info. If i change the diff oil too I want to get a good fully synthetic oil. It seems to be the theme that they didn't exactly break the bank with the oil they used in the Subaru factory
For anyone in Oz also looking there's a couple of local oils with good reputations that might also be ok. Both fully synthetic.
This one over in Queensland with the Gear SYN 7590.
http://www.synforce.com.au/gear_oils.html Scroll down
Also Penrite Pro Gear 75w-90 which I have in my Triton and after trying several is by far the best.
http://www.penriteoil.com.au/product...d_products=376
Old 12-31-2012, 08:53 AM   #126
Cameronghanson
Drives: n/a
That's awful mate. Way to expensive there but if you did want to go that route, on redlines website you put it the make and model and it will find you all the right fluid. Either way, redline or not, changing the fluid seems to be the way to go. Especially tranny fluid.
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 08:07 PM
A problem with new rules in SCCA/NASA regarding FIA seats CyberFormula Other Vehicles & General Automotive Discussions 3 11-09-2011 10:13 AM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 01:49 PM
