Old 11-20-2012, 08:45 PM   #15
TheProspect
TheProspect's Avatar
Drives: Hot-Lava fr-S Smoked Tail Lights
So If I wanted to take the whole panel off and not just the emblem is there clips at all or just 3m tape to keep it stuck on??!?!
My VTec Goes BWwWwWaAAaAaAAAAAaAaHHHHH!!!!!!
TheProspect is offline   Reply With Quote
Old 11-21-2012, 04:44 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
There are 6 clips, 3 visible under the hood and 3 in the door opening/behind the fender as well as the tape.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-09-2012, 05:53 PM   #17
EBMCS03
Drives: Argento FR-S
So is it easiest to try and release the 6 clips somehow? Then pull the side vent out?
EBMCS03 is offline   Reply With Quote
Old 12-09-2012, 06:26 PM   #18
gmookher
I just removed mine by pulling from the outside
Old 12-09-2012, 07:05 PM   #19
calis5nest
calis5nest's Avatar
Drives: scion frs firestorm
http://www.ft86club.com/forums/showthread.php?t=18910
check towards the bottom of pg to see pic of where the clips go and on pg 2 i give a brief description on how I took them off
-Alan
calis5nest is offline   Reply With Quote
Old 12-09-2012, 07:16 PM   #20
EBMCS03
Thanks. start from the side by the door and work your way to the front.
so it looks like there's only tape that runs vertically along the door.
Old 12-09-2012, 07:30 PM   #21
calis5nest
calis5nest's Avatar
yep u got it. tape will be the hardest thing to take off in my opinion
-Alan
Old 01-04-2013, 09:39 PM   #22
Fnbeast86
Drives: Firestorm red fr-s
Why don't you buy the carbon fiber ones those would look nice I'm still debating to do it or not decisions r so hard
Fnbeast86 is offline   Reply With Quote
Old 01-04-2013, 09:43 PM   #23
Fizzle
FizzRS
Fizzle's Avatar
Drives: Scion FR-S Asphalt
Fizzle is offline   Reply With Quote
The Following User Says Thank You to Fizzle For This Useful Post:
TheFRSChick (07-22-2013)
Old 07-24-2013, 03:11 PM   #24
TheFRSChick
TheFRSChick's Avatar
Drives: 2013 Scion FR-S / WhiteOut (37J)
I know this is late lol xD but !! and random, but i swapped these out to put in the BRZ ones into my FRS
there are adhesives on there.. and some clips thatll pop out, but use needle pliers for the side thats under the hood.
-Jenny Nguyen
Follow me on Instagram @TheFrsChick
TheFRSChick is offline   Reply With Quote
The Following 6 Users Say Thank You to TheFRSChick For This Useful Post:
Bonburner (01-30-2014), chanomatik (03-04-2014), Enalband24 (05-26-2015), evolution_sfv (06-13-2015), haimichaeltran (02-07-2017), hmong337 (03-30-2014)
Old 07-27-2013, 03:53 PM   #25
Prichardsfrs
Drives: 2013 scion frs black
Well I just went to Subaru and bought in painted brz vents to replace my FRS ones hopefully this works out well
Prichardsfrs is offline   Reply With Quote
Old 01-25-2014, 04:28 AM   #26
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
How much was that?
Jolaessss is offline   Reply With Quote
Old 01-26-2014, 12:01 AM   #27
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
what kind of tape did you use to put the new one on? thanks! =)
Old 02-05-2014, 12:19 AM   #28
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
New factory fender "vents" should already come ready to go on the car with adhesive already where it needs to be. That's how my TRD ones came, though in different places from the normal GT86 "vents" because of it's different design. I actually removed the stock "vents" from front to back...was pretty easy actually. Taped around the "vent" edge and used a flat wooden tool to lift of the front leading edge so I could use my fingers, then just pried it up all the way to the back where the adhesive was and pulled it off - the clips are designed to pull out with a tug. Hardest part is getting all the adhesive off the car...
Fender with the "vent" off...
Back of the TRD garnish showing adhesive (better than stock because they have adhesive on the front leading edge) and clip locations...
Clean the fender very well and dry then pull off the covering for the adhesive strips on the "vent" and just push it straight into the fender to set in place.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following 2 Users Say Thank You to Vracer111 For This Useful Post:
chanomatik (02-27-2014), SlinkyAvalanche (03-18-2014)
question about brz/fr-s front fender vents nmullin11 Cosmetic Modification (Interior/Exterior/Lighting) 23 03-20-2013 06:01 AM
Functional front fender vents JohnATL Cosmetic Modification (Interior/Exterior/Lighting) 10 01-25-2013 12:58 PM
Remove mirror cover and fender side vents? CharlieChaos DIY (Do-It-Yourself) Guides 5 11-10-2012 04:46 PM
Let's Trade! Silver FRS/BRZ fender vents! YAER Exterior Parts (Aero, Lighting, Etc.) 3 09-18-2012 01:56 PM
Fender Vents real or fake KaliKev Scion FR-S / Toyota 86 GT86 General Forum 48 12-03-2011 02:24 PM
