| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#295 |
Drives: 2013 Firestorm FR-S 6MT
I plan on running a square 17x9 all the way around for autocross, only reason I went with this is because I wanted a staggered setup and really liked these wheels. I work for a scion dealer and we do shows occasionally, so in a sense I guess these are more glamour wheels, I just cant stand the stretched look on these tires.
2013 Firestorm 6MT
2005 Corolla XRS |
#296 | |
KCCO From Canada
Drives: Asphalt FRS
#297 |
VMFIC ORLANDO SCIKOTICS
I am in the same situation. I am ordering 18x8.5 front/ 9.5 rear. I was thinking about 225/40 R18 front and 245/40 R18 rear. What do you guys think about those sizes?
"Silence is acceptance so start talking or quit bitching!"
#298 |
Señor Member
Drives: white BRZ 6MT
^you could go wider unless you are trying to stretch
#299 |
Not really concerned with stretch. You think 255/35 in the rear would be better?
#300 |
I've got a 255 now, the wheel lip slightly pokes out from the tire. I hate it.
2013 Firestorm 6MT
2005 Corolla XRS |
#301 |
What do you hate. Do you want more stretch or are you wanting a 265 or bigger with less stretch?
#302 |
I want no stretch. Gonna try and sell these tires and go wider.
2013 Firestorm 6MT
2005 Corolla XRS |
#303 |
Ashes to ashes.
Drives: Asphalt FR-S
Quick Question...Will they fit?
Im assuming so. They are off a 2007 WRX STI which I believe has a 5 x 100 bolt pattern.
225/45R17 91T Just making sure they will fit. Also, good deal? Thanks for the help! EDIT: Forgot to add the link dur. http://chicago.craigslist.org/chc/pts/3398708756.html Last edited by Double4Free; 11-11-2012 at 12:58 AM. |
#304 |
Drives: 86 ZN6
2007 STI has a 5x114.3 bolt pattern
regular WRX is 5x100 |
#305 |
Ashes to ashes.
Dang, so no fit? It is a 2007 STI. Can anyone confirm?
#306 |
Drives: BRZ(sold), STI
Won't fit.
#307 |
Ashes to ashes.
Fail. Thank you.
#308 |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
they only year STI with 5x100 bolt pattern is 2004, in 2005 they changed to 5x114.3 and have been that way since.
ALL WRXs use 5x100 however. So either look for WRX wheels or 04 (only) STI wheels |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
