Old 10-30-2012, 09:12 PM   #15
stocktc1
Drives: scion tc
I'm actually doing the other way around. Using FR-S rims on the TC.
stocktc1 is offline   Reply With Quote
Old 10-30-2012, 09:16 PM   #16
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Then you'll be fine. If you want rings you can buy them, but if you properly bolt the wheels on (star pattern - evenly tightening lugs up) then you'll be fine. Lugs are tapered to center the wheel on the studs, so as long as they're tightened up properly you won't need hub rings.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 08-05-2015, 01:25 AM   #17
foxygenn
Drives: ChevroletBeretta
There is 56.1 - 54.1 in stock size. CentricRings.COM
foxygenn is offline   Reply With Quote
Old 08-05-2015, 12:27 PM   #18
8R6
8R6's Avatar
Drives: FRS
Originally Posted by foxygenn View Post
There is [URL ="http://www.centricrings.com/centric-rings-size-selector/out-diameter-56.1mm/in-diameter-54.1mm"] 56.1 - 54.1 in stock size. CentricRings.COM
[URL="http://www.centricrings.com/centric-rings-size-selector/out-diameter-56.1mm/in-diameter-54.1mm"][/ URL]
at least you actually used a search button and found a correct thread to advertise your stuff. even if the thread is 3yrs old. lol
8R6 is offline   Reply With Quote
Old 08-05-2015, 12:28 PM   #19
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Necro!
Kuri is offline   Reply With Quote
Hub Bore Correction Wesley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-02-2013 09:00 PM
My FRS baseline VERSUS Visconti e85/Perrin/Injen/Motiv setup TyperRspec789 Engine, Exhaust, Transmission 15 12-24-2012 09:10 PM
Delete driver01 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-08-2012 07:25 PM
Wheel Hub Bore Size feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-08-2012 01:01 AM
Size Comparison: FR-S versus tC and GT-R CSSM FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 58 03-05-2012 11:28 PM
