go_a_way1
Old 10-30-2012, 02:11 PM   #211
empower-auto
Kouki-Monster
empower-auto's Avatar
no problem
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-30-2012, 02:14 PM   #212
MarkRacerX
MarkRacerX's Avatar
Drives: 12' Evo X , prior 1st 86 FR-S
No problem for me on my setup I ran / raced !
http://www.ft86club.com/forums/showthread.php?t=20854
Autocross & Drift = my Anti Drug!!
I have Car A.D.D prior few:
12' Evo GSR, 13' FR-S, 11' STi, 08' 135i, 07' 335Xi,
08' STi, 04' 350Z, 04' STi, 02' WRX. 96' GSR, 04' SE-R/SpecV
MarkRacerX is offline   Reply With Quote
Old 10-30-2012, 02:30 PM   #213
dj petey
dj petey's Avatar
According to Michelin, 8" is the max recommended rim width for the OE tire. However, every other Brand of 215/45/17 on the market that i've seen specs a 8.5" as the max. In the tire stretch scene, this is not even considered a stretch. There is no danger of running this width on the OE tire.
With the safety question answered, the advantage of stretching the sidewall to max spec is that it produces less tire roll during hard cornering thus improving steering response. There is an added benefit of an increased contact patch because more of the shoulder is contacting the ground thus providing more grip.
This tire loading illustration demonstrates the same principle of a narrow rim width vs a wide rim width on the contact patch of a tire.
There are several reasons car manufacturers wouldn't max out rim width and they include but are no limited to cost savings, better fuel economy, weight reduction, and comfort. Cars made for performance tend trade off the above mentioned aspects for better handling and road feedback.
As for damage to the rim, there is slightly less cushioning from the sidewall when it's stretched so there is a slight increase in risk of a pot hole ding but the OE tire is a 215/45 which is less susceptible than a 215/40 or 215/35. Also, as you can see from my pics, the OE tire rim protector is quite large and still protects the rim from most curb rash.
dj petey is offline   Reply With Quote
Old 10-30-2012, 04:48 PM   #214
ok180
Drives: TOYOTA 86 GTS
Thanks for the detailed responses guys! Looks like i will be keeping the OE tires for now.
ok180 is offline   Reply With Quote
Old 10-30-2012, 05:59 PM   #215
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
This is my plan as well in the spring - new 8" wheels with the stock tires for at least a season if not two. Then new tires (either 215 or 225)
Khyron686 is offline   Reply With Quote
Old 10-30-2012, 09:38 PM   #216
giraffee
giraffee's Avatar
Drives: Slowly
I enquired for some wheels today. Advans RS in 17x8 +37 which I thought would fit.
However the Advan rep says 'they are not available for the 86, and listed ones which are available for the 86: 17x8 in offsets such as +48 and +50.
May I ask why he may say this? He hasn't responded to me.
giraffee is offline   Reply With Quote
Old 10-30-2012, 09:48 PM   #217
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
^ no idea.. Some people think 8 +37 is aggressive.
Be sure the pcd is 5x100. , not x114.
"The best track modification you can ever make is between the steering wheel and seat." - CSH
ill86 is offline   Reply With Quote
Old 10-31-2012, 01:11 AM   #218
giraffee
giraffee's Avatar
Drives: Slowly
yeah definitely 5x100, yeah a bit odd to me.. thanks for your input
Old 10-31-2012, 06:04 AM   #219
whataboutbob
AutoX-10/10ths every run
How about a set of stock Scion TC wheels on stock suspension? Found a set on CL cheap and thinking they'd be good starter AutoX wheels...
A bit of Google foo seems to say 17x7 at 45 offset.
Not sure what tires yet...ideas?
Build thread:Here
Old 10-31-2012, 11:49 AM   #220
Ingen
Drives: Ultramarine FR-S 6MT
OK, I'm sure someone has already asked, but I cannot find the thread. I am looking at the 16" package from Tire Rack for winter tires, since the local tire shop admitted they would just order them from TR anyway.
http://www.tirerack.com/wheels/resul...3&autoModClar=
They're a 16x6.5" with a 50mm offset. The rest of the info if needed is at the link. I am thinking of running 205/55R16 Continental winter tires on them.
Thoughts? Thank you so much, btw - this is confusing.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 10-31-2012, 02:22 PM   #221
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
I've got the stock tires on my 17x9.0 Rotas and I abuse them... no issues here.
Old 11-03-2012, 11:48 PM   #222
Mo707
Mo707's Avatar
Can someone help me here?
Should the offset of the front tires be more than the back?
or the other way around?
And has anyone had experience with toyo tires?
Toyo Poxes 4 to be exact.
Mo707 is offline   Reply With Quote
Old 11-04-2012, 09:08 AM   #223
ironchef
ironchef's Avatar
Drives: GLI
Looking at getting RPF1s 18x9.5 +38 all around.
Based on calcs, it looks like the closest match to stock are 245/35/18s.
After that, it's 255/35/18s.
The 255 have a much greater selection of tires then the 245s do.
Currently on stock suspension, and looking to lower it .8-1 inch via either RCE Yellows or something similar, and add OEM camber bolts up front. Will there be an issue with either size?
ironchef is offline   Reply With Quote
Old 11-04-2012, 12:52 PM   #224
ill86
ill86's Avatar
Drives: iG FR-S
So much wheel width, so little tire..
To each their own.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
