Old 10-10-2012, 12:47 AM   #1
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Wheel Directory: VW AVUS Wheels 15x6.0 +38
Originally Posted by TmP View Post
Wheels that don't fit: VW Jetta 15x6 ET38
Wanted to use these as slide around crap ties, but they touch the caliper
They are the stock steel rims with 195 65 15s on 'em.
Putting one on it looked like a perfect fit, but no dice.
Test fitted my old Volkswagen 15" AVUS wheels which I will hopefully be running for the winter. Everything fit on fine, however I did not try driving it around to check for rubbing or any other issues.
The wheels are painted black so they are a bit difficult to see in the picture, but heres one anyway.
Flat Black VW is offline   Reply With Quote
The Following 3 Users Say Thank You to Flat Black VW For This Useful Post:
hippari (10-10-2012), seven (10-10-2012), Silp3 (10-13-2012)
Old 10-10-2012, 02:10 AM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Interesting. Can you determine the wheel width and offset?
Take a few more photos and I will add the wheels to the Wheel Directory.
The Following User Says Thank You to DarrenDriven For This Useful Post:
MiguelAE86 (10-10-2012)
Old 10-10-2012, 02:56 AM   #3
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
I hope you found Ball seat lug nuts, the VW came with ball seat lug bolts, if you put the oem lug nuts on those wheels you could have a safety issue.
Spartan65 is offline   Reply With Quote
The Following User Says Thank You to Spartan65 For This Useful Post:
dsgerbc (10-10-2012)
Old 10-10-2012, 04:46 AM   #4
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
Well this answers my question of 15in steel wheels fitting on the car for winter
seven is offline   Reply With Quote
The Following User Says Thank You to seven For This Useful Post:
Wes B. (11-05-2012)
Old 10-10-2012, 09:53 AM   #5
Flat Black VW
That is why I haven't been able to drive around with them to fully check for rubbing issues. In the pic I had just bolted them up with the stock lugs, took some pics, and swapped them back.
Old 10-10-2012, 01:02 PM   #6
dsgerbc
Drives: BRZ(sold), STI
If anyone knows a source for some ball-seat 12x1.25 lug nuts, I'd like to hear it.
There are some nice 16" BBS VW rims for sale nearby, and I'd love to run them during winter.
To OP: can't see squat on that pic, should've shot it from the other side.
Old 10-10-2012, 01:04 PM   #7
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
very interesting....I may just have to try my corolla's 15" tires on my car after seeing this.
Old 10-10-2012, 01:05 PM   #8
dsgerbc
I tried some 15x6.5 wheels and the ball-joint on the tie-rod rubbed. Some narrow 15" might work. Like 15x5.
The Following User Says Thank You to dsgerbc For This Useful Post:
Old 10-10-2012, 02:32 PM   #9
seven
Tells it like it is
seven's Avatar
Perhaps the offset has something to do with it?
*edit* also these are narrower... they're 15x6
Old 10-10-2012, 02:48 PM   #10
hippari
I Love your GUCCI Wheels!
hippari's Avatar
Drives: Raven Black FR-S
Send a message via AIM to hippari
woah good info guys! And I thought 16's were the absolute smallest we could down size to.
@jinxyboi | @_iLLdynasty
Rice for the Rice God
hippari is offline   Reply With Quote
Old 10-10-2012, 03:03 PM   #11
seven
Tells it like it is
seven's Avatar
Update us on the rubbing or any other issues ASAP if you can.
I have access to these wheels for basically free and would like to use them if possible. What size tires did you have on them?
jfyi the offset of Avus wheels is +38 per this site http://www.myturbodiesel.com/1000q/w...base-5x100.htm it's a 15x6
Even more edit... Per this calc http://www.1010tires.com/WheelOffsetCalculator.asp
Compared to the stock 17x7 with +48 offset vs the 15x6 with +38 offset.... They're should be 23mm MORE clearance inside and 3mm Retracted outside "suck"
Hopefully OP will verify but this SHOULD mean an Avus wheel is a-ok
Old 10-10-2012, 03:19 PM   #12
dsgerbc
Offset was +45
Old 10-10-2012, 05:30 PM   #13
Flat Black VW
Yeah... I only put the wheels on that one side, again it was just test fitting after drinking a few beers and getting bored. I have not driven around with these on and I wont be able to until I find some lugs that work for it. If anyone has a source please let me know.
Old 10-10-2012, 05:40 PM   #14
seven
Tells it like it is
seven's Avatar
http://compare.ebay.com/like/3604928...Types&var=sbar
$25 and in black to match (60 degree acorn = ball-seat IIRC)
Also - http://rad-usa-direct.amazonwebstore...source=froogle = $35 in chrome
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 04:07 PM
Got some new wheels for my DGM BRZ / "DATBRZ" DookDookDGM BRZ Photos, Videos, Wallpapers, Gallery Forum 11 09-11-2012 01:06 PM
>>> MOTEGI WHEELS 17"/18" - INCLUDING MR121/MR125 ROTARY FORGED @ 17 LBS/19 LBS BestWheelDeals Wheels and Tires 2 09-07-2012 10:26 PM
"What kind of wheels are these?" MEGATHREAD switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-04-2012 12:03 AM
How harsh is the ride on 18" vs 17" wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-18-2012 04:08 PM
