#29 |
Drives: vrooom...
I just got one, I'm lucky Mach V is close to home. Here is the link to it on their site: Mach V BRZ/FRS Muffler Delete
#30 |
Drives: 2021 Supra / 2022 Tundra
We were waiting to hear on a dual exit delete option, not the regular delete.
TomR
#31 |
Drives: vrooom...
| The Following User Says Thank You to M1K3 For This Useful Post: | ABQautoxer (09-20-2012) |
#32 |
Drives: GT86
Maybe it would be an idea to make these so that you can attach the stock "big" jdm/edm tips?
Would look the same as stock + awesome sound. |
#35 |
Drives: 2013 DGM BRZ
any pictures on the dual outlet delete? release dates? price range? Thanks.
#36 |
I don't think the person who had the heat issue on the bumper installed an outlet beyond the bumper. Instead, I believe they just disassembled the muffler, leaving the outlet behind the bumper. At a 12.5:1 compression engine, that sucker gets hot.
#37 |
Drives: Black 2013 FRS
The exhaust from a higher compression engine should be cooler due to the fact that increased compression increases the engine's thermal efficiency and there is more of the fuels energy turned into "go", and less turned into thermal energy.
| The Following User Says Thank You to d1ck For This Useful Post: | Silp3 (09-27-2012) |
#38 | |
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
--Dan Mach V |
#39 | |
Learns something new daily! Nonetheless, to some degree there is a higher than usual amount of heat coming out that the bumper's material was never designed to handle the heat |
#40 |
TIG welding on the dual-tip prototype.
![]() --Dan Mach V |
| The Following User Says Thank You to Mach V Dan For This Useful Post: | MannyO (10-08-2012) |
#41 |
Drives: Whiteout FR-S
I like your style, under promise & over deliver is a good motto to have.
| Mach V Springs for BRZ | Mach V Dan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 09-06-2012 03:13 PM |
| Resonator delete? Sound with stock muffler? | Nate219BRZ | Engine, Exhaust, Transmission | 23 | 09-05-2012 06:42 PM |
| Custom Muffler Delete w/ Videos! | IceCreamMan | Engine, Exhaust, Transmission | 5 | 06-28-2012 07:12 PM |
| X-Pipe with Muffler delete | dav0777x | Engine, Exhaust, Transmission | 3 | 06-21-2012 10:30 AM |
