#15 |
Drives: 13 whiteout scion frs
i just bought that cusco front sway for a bit more stiffness...works wonders..
#16 |
Drives: Sterling Silver BRZ
Installed a 16mm WRX rear sway tonight...paid $40 in excellent condition, bolted right in...Test drove it, with the Nannies on, no worries or changes. With the Nannies Off...A little more tail happy, but Not Dangerous. The car is still very predictable...
I say Win. Anything larger than a 16mm would most likely be overkill without further upgrades throughout the suspension...In my opinion.
Activating: ESC POD...let's Drive!! |
#17 | ||
| The Following User Says Thank You to fatoni For This Useful Post: | Dimman (09-16-2012) |
#18 |
Drives: ITR
#19 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
So I've decided to go with the advice given to me earlier in the thread that said to get the wheels/tires first and see if I want sway bars based on my preferences with those installed.
I have some BC Racing Coilovers on their way to me. Other than that I'll wait it out.
| The Following User Says Thank You to ngabdala For This Useful Post: | Calum (09-15-2012) |
#20 |
That Guy
Drives: 2013 asphalt FRS MT
Everything we've seen so far points to this car not needing much to upgrade the suspension. The stock setup is great, 1.0g has been measured with no changes other wheels and tires. I'd say do the wheels and tire, get a good alignment and see where you're at. You could certainly be in the 1.1g area and theres not many people with the space, and skill to take full advantage of that.
Most cars, yes absolutely you should start with the suspension, but this isn't the norm. My personal plans are to put sticky tires on the stock rims, get some com-c top hats for the front and camber adjustment front and rear. Find an alignment I like and leave the suspension alone from there. I might get some regular guy springs from RC, but at the moment I'm not sure if I'd want them. |
#21 |
WRX '08-'11 Rear Sway bar...16mm. It uses the exact same End links so there is no need to remove them. Unbolt the end links (one nut each side) and the bushing caps (2 each side). Remove the stock bar. Shimmy the WRX into place. Thumb thread the 14mm nuts on the end links to to hold the bar in place. Thread the bushing cap bolts (12mm) and center the bar. Then lock it all down. Test Drive!! With TRAC off...she is tail happy!! with TRAC on...in Sport mode she flicks a bit, but in Normal Trac on all the fun buttons off...She's smooth sailing. For me at least...
My Wife and I decided on Pink... ![]() All done...25 minutes install on the ground, of course the Nameless exhaust left me plenty of room to work under there without jacks. ![]() Enjoy!
| The Following User Says Thank You to ESC POD For This Useful Post: | huma (09-15-2012) |
#22 |
Drives: ITR
I didn't fully understand, so it uses all the same hardware from the BRZ? In your pics, it looks like you have new bushings/mounts for the bar. I didn't know if the BRZ bushings/mounts would work since it's for a smaller bar.
#23 | |
Hope that helps!
| The Following User Says Thank You to ESC POD For This Useful Post: | huma (09-16-2012) |
#24 |
Drives: ITR
Thanks, understood now. Going to my dealership later this week to see how much it'll cost for everything (:
#25 |
That Guy
#26 | |
Drives: Asphalt FRS
#27 | ||
#28 |
Drives: Asphalt FRS
WHAT? ![]() Please explain why you believe this is so. If that were true then we would have solid, not rubber or urethane bushings everywhere. A little "give" is necessary without question. (for a road car) If you've ever driven or rode in a battle tank, it would be crystal to you. |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Sway Bar Upgrades | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 51 | 09-01-2012 06:43 PM |
| AMT rear sway bar bracket | adamturbo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 06-13-2012 11:06 AM |
| adjustable sway bars!!! | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 05-04-2012 08:42 AM |
| STI rear sway bar | carbonBLUE | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 03-25-2012 12:58 PM |
