Old 09-13-2012, 07:22 PM   #15
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
[ame="http://www.youtube.com/watch?v=iPMRiYN0Odk&feature=g-vrec"]2013 Subaru BRZ - First Oil Change with Torco 100% Synthetic SR-1 - YouTube[/ame]
2URGSE
JPxM0Dz is offline   Reply With Quote
The Following User Says Thank You to JPxM0Dz For This Useful Post:
Marrk (09-16-2012)
Old 09-13-2012, 07:42 PM   #16
ducks
Drives: car
found this:
http://www.bobistheoilguy.com/forums...47#Post2710647
UOA of the original factory oil
ducks is offline   Reply With Quote
The Following User Says Thank You to ducks For This Useful Post:
Marrk (09-16-2012)
Old 09-14-2012, 02:30 AM   #17
zoomzoomers
zoomzoomers's Avatar
Originally Posted by JPxM0Dz View Post
So this Torco 10w30 100% synthetic oil is good stuff? I might have to give it a try.
Old 09-14-2012, 02:21 PM   #18
Alienate
Drives: 2013 Scion FRS
First Oil change with use of a MAGNET
I like to do my first oil change at 500 miles. I did so today. After draining the OEM oil, I ran a large magnet thru the oil catch pan. The results were quite surprising.
The magnet picked up HUNDREDS of metal shards, some as big as a quarter inch.
The attached photo shows the gory details.
Alienate is offline   Reply With Quote
The Following 4 Users Say Thank You to Alienate For This Useful Post:
Anthonytpt (03-15-2013), ducatichick (12-19-2012), Marrk (09-16-2012), Packofcrows (09-13-2015)
Old 09-14-2012, 03:51 PM   #19
eclipsed
Drives: Firestorm Fr-S
That is one scary picture. That's a lot of metal floating around in the oil...
eclipsed is offline   Reply With Quote
Old 09-14-2012, 05:24 PM   #20
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Hence the need for a Filtermag
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
@Art_Mighty (09-15-2012)
Old 09-15-2012, 12:11 PM   #21
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Which of the three sizes will work for our cars (mines in the shop with a CEL so I can't measure)
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 09-15-2012, 01:42 PM   #22
tonystewart
RA-300
Old 09-16-2012, 01:56 AM   #23
_hollywood
Drives: 97 itr sold
Im waiting till 7500 ill let you guys know if my engine blows up....
Remember they design these cars to be idiot proof, even if you change your oil every 3k one accidental shift into 3rd instead of 5th will do more damage than i will by going with the oem recommended maintenance schedule....
My 2 cents
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
The Following User Says Thank You to _hollywood For This Useful Post:
suaveflooder (03-13-2013)
Old 09-16-2012, 02:00 AM   #24
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Lord knows I've bounced off the rev limiter down shifting by accident. There's safeguards in place for that... Btw, changed the oil at 7500 with amsoil... Runs the same with better mileage
I'll be back!!
F3dzo is offline   Reply With Quote
Old 09-16-2012, 02:06 AM   #25
_hollywood
Drives: 97 itr sold
Originally Posted by ducks View Post
found this:
The numbers dont lie, on older cars i always change every 5k but times have changed i think we will all be ok to wait, unless you are competing in 24hr challenges every weekend
Old 09-16-2012, 12:05 PM   #26
Marrk
Drives: Honda Fit
Okay. But it all goes back to the old argument: Is there such a thing as "break-in oil from the factory"? If the high moly content on that Blackstone report is to be understood as an intended and necessary break-in additive, then perhaps we should not change the oil early. However, some have argued that high moly amounts are the result of engine assembly paste on a new build and are not put there for break-in purposes.
Nobody knows the answer to this mystery.
Marrk is offline   Reply With Quote
Old 09-16-2012, 12:07 PM   #27
Marrk
Drives: Honda Fit
_hollywood is referring to a mechanical over-rev. There is no safeguard for that. You could probably look it up somewhere (no sarcasm intended).
The Following User Says Thank You to Marrk For This Useful Post:
chulooz (09-16-2012)
Old 09-16-2012, 12:15 PM   #28
F3dzo
F3dzo's Avatar
Ohhhh
I'll be back!!
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 03:42 AM
3,000 mi oil-change prest1ge Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 10-29-2012 08:13 PM
Took my car in for an oil change... joshua BRZ First-Gen (2012+) — General Topics 25 08-04-2012 10:32 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 08:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 05:44 AM
