View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 09-12-2012, 12:24 PM   #883
travace
travace's Avatar
Drives: Scion FR-S
Originally Posted by Sh0tym3 View Post
Hey guys,
I've said it before and I'll say it again lol. Take the car to the dealer. I took mine in and found out its the fuel pump. Replaced the fuel pump with a new one and now the noise is gone
No more trying to find gas that cancels out the noise.
Quick fix guys.
would be nice... took mine in 2 times and they still tell me its normal.
then again im not sure about this dealer... they told me they put on a suspension fit kit for the rear tapping noise that everyone and myself are/were having. which is way different fix then what everyone else is saying fixed theirs
im going somewhere else soon.
travace is offline   Reply With Quote
Old 09-12-2012, 12:35 PM   #884
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Hey guys,
Quick fix guys.
Did you get the engine really hot yet via some spirited driving yet? Fill up with E10 91 or 93 octane gas yet?
Old 09-12-2012, 12:58 PM   #885
Sh0tym3
Drives: 2013 Scion FR-S, Silver
They didn't just replace it with the same fuel pump. It's a new one that Toyota built because the old one is faulty.
As for how many KM's. Not too much. Been about 200KM so far and yes I fill up on 91 all the time and drift like a maniac
I'll let you guys know if it comes back in the next 800KM but I think it's fixed.
Sh0tym3 is offline   Reply With Quote
Old 09-12-2012, 01:10 PM   #886
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Just joined and this was one of the first things I searched for. Drives me nuts at drive-thrus. Mine started when I left the lot from my 3k oil change, but it didn't seem consistent so I forgot about it for a while.
Last weekend I decided to fiddle with removing my DRLs. All I really did was remove/replace the front plastic under-cover and the chirping went away. I could still hear the DI tick-tick but mostly with the hood up. It was a definite change.
After a trip up to Palomar Mountain, I started hearing it again. I figured it was due to the underside of the car being held together by plastic pop-clips. But I'm just over 7k now and will be taking it in for the oil change and have them check it out.
Someone mentioned AC on/off. I have a different noise associated with the blower motor. AC on/off doesn't matter, it's if the fan motor is running at all. At lower fan speeds, the sound isn't so bad. But it's been hot here and when it's on full blast, it's really annoying. I'll be having the dealer check that as well, but wanted to point out someone may be associating it with another issue.
2point0 is offline   Reply With Quote
Old 09-12-2012, 02:05 PM   #887
ATL BRZ
ATL BRZ's Avatar
I wasn't aware that a new revised DI fuel pump was available? Can you please post the part # so we can compare it to the faulty pump part #?
I thought this would come out as a TSB, but apparently there isn't one out yet.
The Following User Says Thank You to ATL BRZ For This Useful Post:
alrashwa (09-12-2012)
Old 09-12-2012, 04:29 PM   #888
ROBOSTIG
Drives: 2013 Firestorm Red FR-S MT
700 miles and I can hear it chirping away. Don't remember my 06 STi making this noise. Not the same engine I know, but this shouldn't be an issue. Watching this thread!
ROBOSTIG is offline   Reply With Quote
Old 09-12-2012, 04:39 PM   #889
Shaglounge
Drives: FRS, 96 Miata, 64 Mgb
1400km (800 miles) chirping when hot.
Always some headaches with first year cars... I know its been covered already lots
This is nothing to my then new 09 Mini JCW, High pressure fuel pump failure, and then cam chain tensioner failure in 300km. BMW/Mini refused to stand behind their product and repair. Traded it in 3 weeks later, for a Toyota. Good riddance.
Shaglounge is offline   Reply With Quote
The Following User Says Thank You to Shaglounge For This Useful Post:
Marrk (09-12-2012)
Old 09-12-2012, 05:26 PM   #890
ROBOSTIG
08 MINI Cooper S after the STi... great car when under warranty. Until I had to pay for Chain tensioner and waste gate failure and bunch of other things before I traded it in. That MINI was built for weekends, not daily drives.
I'm hoping these issues with the FR-S won't hurt my opinion of this car.
The Following User Says Thank You to ROBOSTIG For This Useful Post:
Marrk (09-12-2012)
Old 09-12-2012, 05:33 PM   #891
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by gmookher View Post
has SOA seen this thread?(scion of america, subaru of america)
SOA does not care about what is happening to any other owner, other than the person whose issue is in front of them at the time, I called SOA, took my car to the dealer and they ordered the revised pump, There is no TBA and probably never will be unless all of the people here in this forum go to the delaer and have the dealer call SOA while they are there. If you want the issue resolved get involved. No use wondering or pondering about it, if the dealer trys to blow you off like mine did call SOA 1-866-707-2466 open a case and be entitled to resolution.
Spartan65 is offline   Reply With Quote
Old 09-12-2012, 05:42 PM   #892
alrashwa
alrashwa's Avatar
Drives: '12 370Z Monterey Blue
Spartan, Is this the same DI pump mentioned by Curt previously?:
Originally Posted by Curt Aigner View Post
The chirping noise is from the high-speed fuel pump located on the top of the motor. Toyota is aware of the problem. A TSB will be issued in a few weeks . The high-speed fuel pump will be replaced with a modified unit. The pumps are in production and intransit from Japan. When all of the USA warehouses have inventory on the new pump the TSB will be releasd and available for the dealers to order.
How do I know ? I also own a GT86, and have been the parts manager at this dealership for 30 years with a good friend in the powertrain division at TMS Calif.
alrashwa is offline   Reply With Quote
Old 09-12-2012, 07:03 PM   #893
Spartan65
Spartan65's Avatar
Aye Aye Captain
Old 09-12-2012, 07:14 PM   #894
ayetothejay
ayetothejay's Avatar
took mine to the dealer (I'm here right now as I type this) and the certified mechanic for the frs (didn't know Toyota requires that) said the exact same thing everyone is saying, it's the di pump that is making the chirp. he is currently ordering the replacement part for me.
ayetothejay is offline   Reply With Quote
The Following 2 Users Say Thank You to ayetothejay For This Useful Post:
alrashwa (09-12-2012), Marrk (09-12-2012)
Old 09-12-2012, 07:22 PM   #895
alrashwa
alrashwa's Avatar
Guess I'm going back
Old 09-13-2012, 03:11 AM   #896
alrashwa
alrashwa's Avatar
Looking back to June, I found the following post in another thread:
http://www.ft86club.com/forums/showpost.php?p=273052&postcount=95
The part replaced was: SU003-00328 PMP AY-FUEL.H PRS
Which is for the DI fuel pump. I'm curious, anyone here that has already had their part replaced, is this the same part number for the replacement they installed? If it dates back to June, something tells me this isn't a redesigned DI pump. Would they use the same part number for a revised part? Just trying to get to the bottom of this issue.
The Following User Says Thank You to alrashwa For This Useful Post:
ATL BRZ (09-13-2012)
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
