Old 08-30-2012, 12:25 PM   #1
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Suspension Review: KW v3 Coilovers
Lifted from another topic...
Installation note: When installing these KWs we measured the amount of exposed threads below the lower spring collar to determine where to set the coilovers for future installations.
Front: 3/8" remaining thread = 1 9/16" drop
...12 7/8" distance from fender to center of hub (14 7/16" stock height)
Rear: 2 1/8" remaining thread = 2 1/4" drop
...12 3/8" distance from fender to center of hub (14 5/8" stock height)
Originally Posted by Scooby South View Post
Bliss is getting a great package from FEDEX...and then looking forward to putting on something to make a difference.... Thanks StranoParts...
going to wait til after work tomorrow night to install...that way I can read the manual...and study what I need to do...I wanted to install them tonight...but I wanted to make sure I get these absolutely perfect..
Bill
The Following 2 Users Say Thank You to DarrenDriven For This Useful Post:
Anthonytpt (04-24-2013), RAYSSPL (09-05-2012)
Old 08-30-2012, 12:25 PM   #2
DarrenDriven
NW Region Moderator
ok....KW's are ON...OMG...it is a sexy beast and man is it 'PLANTED'..... There is at least an inch of clearance between the tire and the Strut... sooo Camber isn't going to be an issue...AT ALL.. will easily fit 265's..if needed... So...STX...STR.....BRING IT...Its amazing how much Decent suspension does to a car...Installation...I give a 6...the front was no problem..however the ABS and Brake line is routed kinda funky..but I adapted and overcame the Rear.. was a bit more stubborn...but I got it...finally.. Stock 14mm rear sway is on now..with Kartboy links..running Recommended settings for now.. went on a short 'test' drive... I can't wait to get this thing on the course now......I LOVE the KW's...easy to tune... and pretty easy to adjust....I was going to have an event tomorrow but I didn't get to the alignment ...so Monday after work...then I also need to corner weight it.....so far...I am absolutely Beyond pleased with the KW's...They Got it right....On to the pics..
Stock Front Strut assembly....12.6 lbs...
KW Front Strut assembly... 12.9 lbs...
Fronts.... adjusting the ride height..
Front ...After adjustment...about a 1 inch gap between the top of the tire and fender... Coool thing of note...All 4 fenders are Factory Rolled..so nooo issue whatsoever with fitment...
Obligatory Side shot..
and...the Side Profile shot...soooo Sexy..
Can't wait for Cent Divs Next week in Milwaukee.... running up our good buddy Neal Tovsen...and his wife in STX...should be interesting.. ...we'll see how it does against a well prepped Bimmer..
More later
Bill
Anthonytpt (04-24-2013), Tristor (02-28-2018)
Old 08-30-2012, 12:27 PM   #3
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
perfect stance with a great coilover.
VSGTS14 is offline   Reply With Quote
Old 08-30-2012, 12:27 PM   #4
DarrenDriven
NW Region Moderator
Still lifted...
The Following User Says Thank You to DarrenDriven For This Useful Post:
Old 08-30-2012, 02:27 PM   #5
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Hello all.. I am the one that owns the car above...Thanks Darren..
Questions??
Scooby South is offline   Reply With Quote
Old 08-30-2012, 02:35 PM   #6
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
yes, do the kws come with their own top hats?
Old 08-30-2012, 02:44 PM   #7
BRZranger
Hello all.. I am the one that owns the car above...Thanks Darrin..
Questions??
How much lower are you?
What settings did you use for rebound/compression?
I have V3s also, and I love them. The ride does feel more "planted", but I will have to take some time to mess with the settings and fine tune it for my daily driving. I really like how adjustable it is.
I went about 1 3/4" lower, not sure if that is too much, but feels good right now. Supposedly going that low affects the suspension geometry drastically, requiring parts to compensate for the new roll center.
BRZranger is offline   Reply With Quote
Old 08-30-2012, 03:11 PM   #8
gmookher
bery nice
Old 08-30-2012, 03:48 PM   #9
Duo
Drives: 86 pending move
Questions??
This will seem like an odd question, but can you please tell/PM me the box's dimensions? Trying to figure something out.
Motorsports: Because basketball, baseball, and football only require one ball.
Duo is offline   Reply With Quote
Old 08-30-2012, 05:03 PM   #10
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Questions??
Sweet set up! What are the specs on you wheels and tires?
Apex Chase is offline   Reply With Quote
Old 08-30-2012, 05:08 PM   #11
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Awesome set of coils enjoy them.
You going to be at nationals?
FT-86 SpeedFactory is offline   Reply With Quote
Old 08-30-2012, 05:17 PM   #12
jamal
jamal's Avatar
Drives: Legacy GT
No. They work with the stock tops, or you can get aftermarket plates for them. KW does make tops for some of their motorsports stuff but it is usually better to just use something else. RCE/GTworx and Vorshlag both have nice tops.
jamal is offline   Reply With Quote
Old 08-30-2012, 05:34 PM   #13
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
that's what i wanted to know, thanks man. i have vorshalg on my sti, they are nice!
Old 08-30-2012, 08:52 PM   #14
Scooby South
Conedancer
No...the Stockers will work...I have plates on the front and the stockers on the rear...
Camber set at -2.5 zero toe front
Camber set rear -1.75, 1/16th toe in
Mine measures from the bottom of the rim to the arch in the fender...23" front 23 1/4" rear..
Pretty much went with the Stock Settings from the factory in the Setup guide and adjusted from there..
Everybody has a different opinion on where to setup the car... It really is a personal preference... I kinda like a little bit of tightness..so I set up my car accordingly.. What works for me might not be the best option for you... start with the factory settings... then learn to adjust from there..
Originally Posted by gmookher View Post
bery nice
Danka..
I will have to dig it out of the garage ..(in the attic)
17x9 with a 42. 245/40/17 Hankook RS-3's... I will be running in ST Class.. either STX or STR... the car with Coilovers can easily fit 265's if needed...probably will go up to a 255 for the extra gearing... topping out right now at 59.6 in 2nd.. so should easily be 61 or so with a bit taller tire.. 255/40/17
Not this year.... Not Classed yet...After Nats it will be then Next year making a full assault on ST* whatever class..
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
BRZranger (08-30-2012)
BRZ/FR-S Suspension Options List (Springs and Coilovers) WingsofWar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 333 02-01-2022 06:32 PM
Suspension Review: Eibach Pro-Kit Lowering Springs DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 136 10-09-2020 07:26 PM
Suspension Review: Eibach Sportline Lowering Springs DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 07-23-2019 10:59 PM
Suspension Review: Hotchkis Sport Springs Nitro22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 02-23-2016 07:01 PM
Suspension / Coilovers ~ How to Choose the Right Setup for YOU Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 09-24-2015 02:53 PM
