Old 08-28-2012, 06:21 PM   #309
MattQ-WP
MattQ-WP's Avatar
Drives: Pearl White
Subscribed and ammped!!
An opinion is like a bad smell, every A$$HOLE has one!
INITIAL DRIVING CLIP
MattQ-WP is offline   Reply With Quote
Old 08-28-2012, 07:53 PM   #310
subatoy
subatoy's Avatar
Drives: subatoy
I'm not kidding when I say this turbo kit is the difference between me buying this car or not.
the benefits of this kit to me are:
-Getting the real boxer sound.
-Conservative boost with great gains while retaining reliability.
-This is the only reasonably priced turbo kit I've seen probably EVER.
-AVO is known for quality and have been turboharging subies for ever.
If this AVO announces official pricing and it's under $3,600 I'm not kidding when I say I'll buy the kit before I even buy the car.
I'm watching you guys closely!
subatoy is offline   Reply With Quote
Old 08-28-2012, 08:30 PM   #311
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
If the initial pricing is around that, I'm going to cut AVO a check on the spot and then hit John up for a turbo tune, done deal. AVO has a great reputation in the 2.5 RS community and I'm glad to say that it appears they are continuing on with that tradition for the FT86 platform.
One of my biggest regrets is never buying an AVO kit for my RS Ehh, the EJ25 doesn't take to boost nearly as well as the FA20 anyway...
vubaru is offline   Reply With Quote
Old 08-28-2012, 10:51 PM   #312
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Same. I love the design of the kit and how stealth it is.
Question though - I'm not well versed when it comes to turbos, what's the difference between internally and externally wastegated turbos? Which is better?
Sent from my Nexus S using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-28-2012, 10:53 PM   #313
Visconti
Drives: 05 STi
Can't wait !
Visconti is offline   Reply With Quote
Old 08-28-2012, 11:09 PM   #314
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Can you guys fabricate an Even Length Header and leave that as an option?
Seeing how it lines up to the stock set up I'd assume it'd be great and increase sales ~
Old 08-28-2012, 11:17 PM   #315
vubaru
Now with Boost!
vubaru's Avatar
Can't wait !
I have a free Southwest roundtrip flight to your bay area city of choice... either that, or there's always Vegas in Nov.
Gotta get my hands on this kit.
Old 08-28-2012, 11:22 PM   #316
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by AVOturboworld View Post
I realized that the initial photo probably didn't show it very well, so I've edited it a bit:
We have a cast "bellhousing" section that bolts to the turbocharger exhaust housing - essentially a shorty downpipe. This runs back and bolts to the stock location secondary cat. This maintains the stock exhaust profile.
So any exhaust systems, stock or aftermarket, that would have bolted up to the stock exhaust manifold will be able to bolt up to our turbocharger kit.
Smart cookie!
Lemme know when you can take my money please.
Ironsquid is offline   Reply With Quote
Old 08-28-2012, 11:27 PM   #317
AVOturboworld
OEM Turbochargers are, in general, internally wastegated to bleed off boost pressure into the exhaust. It is easier to package that way, and is quieter.
External wastegates became popular because many aftermarket turbochargers simply use an OEM or off the shelf exhaust housing, and the internal wastegate wasn't large enough to keep up with the higher boost of larger compressor wheels that were fit. It would overpower the small wastegates, and boost creep would come into play. The solution was to simply move that to an external wastegate setup.
There is, of course, another solution - make a larger exhaust housing with larger wastegate. However, that solution requires somebody to actually cast and mill the housings themselves. To toot our own horn, and to be also totally blunt about it, we are one of the few that make our own exhaust and compressor housings. Thus we haven't gone down the external wastegate path - if there were boost creep issues, we'd engineer that issue out on the exhaust housings. That's why our AVO380's are running just fine at 30psi on diesel racing trucks on an internal wastegate setup.
But lets be realistic here - a 12:1 compression 2.0-liter engine isn't going to run 30psi, other than on very exotic builds. 5-10psi is likely the limit on a "street" build that's both daily driver friendly and reliable. At those psi/boost levels internal vs. external wastegating is not much of an issue.
Old 08-28-2012, 11:34 PM   #318
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
I know you mentioned the welding in the picture is just for placement. I've seen some turbo headers crack welds under heat/pressure/weight.
Any cross weld bracing for final product? Doesn't look like is can handle the weight of the turbo with the heat and vibrations.
Unless there's a bracket holding the turbo somewhere that I can't see.
Old 08-29-2012, 12:03 AM   #319
AVOturboworld
There will be a bracket holding the turbo in place - we wouldn't have the exhaust manifold holding it in place unless we did a cast nickel-iron exhaust manifold! (which, admittedly, we have done on the LS1 twin turbo kits) But not on this!
Old 08-29-2012, 12:14 AM   #320
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Lol, cast iron mani, that would ruin the weight bias quite a bit!!
Sounds good, price is good, count me in for first couple of orders, I've read alot of good things about AVO so far.
Old 08-29-2012, 09:04 AM   #321
sirus
86 Owner
sirus's Avatar
Drives: White GTS 86
I'm excited!! My wife... not so much... Can't wait to see the results!
On the road. Check your mirrors!
sirus is offline   Reply With Quote
Old 08-29-2012, 09:09 AM   #322
2forme
This is awesome news for us with the SRT header back exhaust system already.
This kit looks like it would be a snap to install/take off if going to the dealer for anything. The price is certainly right. All I need is a dyno graph and I'm sold. Then I can finally steal @Visconti for a day and we can have our own turbo fun haha
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
