Old 08-27-2012, 03:35 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
How necessary is alignment after installing new springs?
I've heard it's always necessary in the past. Until I installed springs/struts myself on my MR2 and again on my G35 and did not see any way to play with alignment. Everything bolted in one way. Things might've shifted a tenth of a degree or two but stayed within the spec range. A mechanic friend of mine also did not believe an alignment necessary for this straightforward job. Now if we start unbolting things beyond the struts (suspension arms, etc.), then it becomes necessary.
I don't have any tools in my new apartment so I'm getting a dealership to install my springs. They say a $90 alignment is necessary, at least on the front pair. Are they trying to gouge me for money/how necessary is this?
EDIT: This question is for a mild 0.6" drop all around.
Old 08-27-2012, 03:37 PM   #2
Racecomp Engineering
It's necessary.
Just because things only bolt in one way, the changes in ride height change alignment.
- Andrew
20valvewynn83 (11-12-2012), flippy (04-17-2015)
Old 08-27-2012, 03:38 PM   #3
Visconti
Drives: 05 STi
Very necessary
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
Old 08-27-2012, 04:00 PM   #4
jadewbj
jadewbj's Avatar
Yes, very needed. You have changed geometry of the suspension.
jadewbj is offline   Reply With Quote
Old 08-27-2012, 04:12 PM   #5
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Ever see a civic that is lowered and looks duck footed/ pigeon toed? Thats a ricer that sprung for the springs and never paid for an alignment...
RandomHero is offline   Reply With Quote
The Following User Says Thank You to RandomHero For This Useful Post:
BabaYaga (02-19-2015)
Old 08-27-2012, 04:18 PM   #6
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
It's necessary.
- Andrew
Anytime you change ride height you need an alignment.
Apex Chase is offline   Reply With Quote
Old 08-27-2012, 04:30 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
100% Necessary. Even the slight play in the bolts can effect your alignment.
Rule of thumb: If you mess with the suspension at all, get an alignment. Sway bars are the only exception as they are not locating members of the suspension.
Old 08-27-2012, 06:53 PM   #8
empower-auto
Kouki-Monster
empower-auto's Avatar
Depends really..
If you read, for example, the Eibach Pro-Kit alignment specs for before and after install - you really don't have to adjust anything on a new, straight, car.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 08-27-2012, 07:29 PM   #9
switchlanez
It's necessary.
- Andrew
Thanks for all the responses. But like I mentioned earlier, my alignment remained within the OEM specified range after I swapped the springs/struts out myself leading me to believe that even the slight play in bolts had not much effect. I've watched shops adjust my alignment and noticed they don't adjust any strut housing bolts that I touch when I install springs/struts. They're torquing bolts in the suspension arms that I never touched. I guess my question should be have any of you guys gone out of alignment when only installing <1" drop springs/struts? It's easy to say, yes, it theoretically could happen. But I wonder if anyone has experienced this firsthand because my firsthand experience (twice) tells me the change in alignment is negligible.
Originally Posted by empower-auto View Post
Depends really..
The Eibach Pro-Kit is a 1" drop. The springs I'm installing are only a 0.6" drop developed specifically to work with the OEM struts. Is 0.6" really enough to put geometry out of spec?
Old 08-27-2012, 07:44 PM   #10
RWD-boxer
RWD-boxer's Avatar
Drives: Black
90$ is cheap for a dealer... Do it
RWD-boxer is offline   Reply With Quote
Old 08-27-2012, 07:44 PM   #11
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
the rear toe setting change was negligible with a 1" drop. I didn't change it after measuring. And considering rear camber isn't adjustable, I was fine. The front "may" be the same if you don't touch camber, but I added 3 degrees, and consequently hand to adjust toe.
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 08-27-2012, 08:30 PM   #12
switchlanez
I'm going to have the reputable Subaru shop only install my springs for $700. They're already upcharging me compared to $550 at the less reputable Subaru shop which hasn't installed any springs "in a while." That's why I'm hesitant to throw more money at the 1st shop for an alignment. Then I'm going to a nearby tire shop for a free alignment check and, if needed, $80 for alignment. But the tire shop doesn't have access to alignment specs for any 2013 models.
Does anyone have the BRZ alignment specs they can send me?
Old 08-27-2012, 08:39 PM   #13
empower-auto
Kouki-Monster
Geez. Just burn your wallet man.
Rich Anderson
EMPOWER AUTO
The Following User Says Thank You to empower-auto For This Useful Post:
Old 08-27-2012, 08:46 PM   #14
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
If you're going to lower the car the wrong way, then just cut the springs and no alignment the cheap way.
Not recommended of course
n8dog11914 is offline   Reply With Quote
The Following User Says Thank You to n8dog11914 For This Useful Post:
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 05:15 PM
Installing BRZ Trunk Interior Liner into FR-S DarrenDriven DIY (Do-It-Yourself) Guides 30 11-19-2016 03:06 AM
alignment with Eibach springs? zooki Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-17-2012 12:34 PM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 03:08 PM
[FR-S] Installing New Subwoofer and Mono Amp hx3 Electronics | Audio | NAV | Infotainment 0 08-09-2012 08:12 PM
