Old 07-13-2012, 02:17 AM   #43
drew935
Auto Salon Works
drew935's Avatar
Drives: wrb
Good results with the eibachs. Looks like the car should have came like that from the manufacturer.
drew935 is offline   Reply With Quote
Old 08-26-2012, 12:55 PM   #44
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
FWIW, you do NOT need to remove the bolt holding the rear LCA to the rear hub assembly. Removing/loosening the nut is all that is needed as it removes the compression force against the rear shock. Then simply have someone put force on the rear brake drum and the damper comes right out, no problem at all
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
F3dzo (08-26-2012)
Old 08-26-2012, 12:56 PM   #45
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Pics of two "proper" tools for top hat shaft nut removal will be posted in here soon. Darren can incorporate in his initial thread as needed/desired.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-27-2012, 11:15 AM   #46
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
It's so easy when you remove the control arm bolts, though, that I just do it. I usually do my installs solo, so don't have an extra person to hold the brake anyway.
Look forward to the photos for properly removing the strut hats.
Old 08-27-2012, 11:18 AM   #47
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
In the rear a helper is nice anyways to avoid dropping the damper
The drivers side bolt wouldn't come out in the 2 seconds we tried (hitting other suspension arms, gave up pushed down on brake and removed damper. Seemed easier to me
Will post the pics today if I get a second.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-27-2012, 12:20 PM   #48
wootwoot
Drives: FRS
There was a thread in the suspension section about a guy that ruined his shocks by tightening the top nut down with an impact wrench. Apparently you are suppose to support the strut somehow to keep it from turning to avoid damaging the seals. How did you handle this with your install?
http://www.ft86club.com/forums/showthread.php?t=14599
Old 08-27-2012, 01:47 PM   #49
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's what I'll post pics of soon. I used two different tools (well I really just used one but took pics of two). One was provided by Tony Jackson @ Eibach who was at an event I run and that Eibach was a Sponsor of, and the other is a simple pass thru ratchet.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-27-2012, 05:35 PM   #50
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Pics of the proper tools. Note, these both require spring compressors to be safe and I took these pics after the spring swap (was in a hurry to do the springs between the end of track sessions and our event banquet), normally you wouldn't use them on the car except to break the bolt loose.
First, the tool brought by Eibach. Not sure where you would find this one but you could make it (weld 3/8" or 1/2" drive socket to a steel bar):
Second, the GearRatchet made by Gearwrench:
And looking through the hole in the middle of the gearratchet setup:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following 2 Users Say Thank You to Dave-ROR For This Useful Post:
Fly Guy (12-04-2012), JimmyMac (09-23-2012)
Old 08-27-2012, 05:40 PM   #51
F3dzo
F3dzo's Avatar
Drives: 13 fr-s whiteout
Is that your car? Clean that mud man!!!
I'll be back!!
F3dzo is offline   Reply With Quote
Old 08-27-2012, 05:46 PM   #52
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Bah.
Not my fault Subaru didn't seal the engine bay worth crap. That's ~6,200 miles of driving when those pics were taken last tuesday (~7900 now).
The engine bay might get cleaned once a year.. at best.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 08-28-2012, 01:18 AM   #53
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
This plus the spring compressor are priceless tools for this install.
Rick
RallySport Direct is offline   Reply With Quote
Old 08-28-2012, 03:58 PM   #54
F3dzo
F3dzo's Avatar
Come to my shop, I'll install your springs ASAP... Hahah this was the easiest way to compress my struts
I'll be back!!
Old 09-10-2012, 02:34 PM   #55
xjohnx
Grip>Slip
xjohnx's Avatar
so it's safe to use an impact to remove the top nut from the strut, just as long as you don't use an impact when replacing the nut during reassembly, correct?
Old 09-10-2012, 02:37 PM   #56
F3dzo
F3dzo's Avatar
It's not that tight to use an impact. Just secure the center shaft with an Allen key and a curved box wrench... Might have to modify the wrench to get in there... Make sure the shock has the spring compressors on.
I'll be back!!
Replacing the Scion FR-S seats bloomy116 Scion FR-S / Toyota 86 GT86 General Forum 36 11-09-2012 01:41 PM
Installing TRD Parts / Locating a good shop Re~Mix Engine, Exhaust, Transmission 9 06-12-2012 01:05 PM
T1R Coil-over suspension AJ PwR Brakes, Suspension, Chassis 33 05-29-2012 11:07 PM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 05:07 PM
