Drives: 2013 Subaru BRZ
3.90 GR86 Diff in a 2013 BRZ - Good combo for boost?
I ran my first dry event with my new turbo setup today. I'm running a 4.30 diff in my 2013 and I ran out of gear very quickly and frequently. Everything I'm seeing/reading seems to indicate that the 3.90 from the 22+ GR86/BRZ automatics would work in my car. Is that the general consensus?
#2 | |
#3 |
Full Throttle!
Drives: 17 CBSP Limited PP
I think that would be a good change for your setup.
Let us know how it goes! |
| The Following User Says Thank You to smackrel For This Useful Post: | RT-BRZ (05-30-2025) |
#4 | |
Kyle H. - #89 STX
#5 |
#6 | |
Even NA I was close to topping out 5th even on the 4.1
Kyle H. - #89 STX
#7 | |
Honestly, that was a pain but there were so many other places on the track where I was losing time because I was at the top of the RPM range but I didn't want to shift up only to have to shift back down almost immediately. The front straight into turn one, the entrance into the chicane, and the exit in Thunder Valley were all like that. |
#8 | |
Drives: Nevermorange FRS
SCCA T4 - FRS
#9 |
Let's figure it out. The shipping weight on my "new" one is showing as 82lbs. Shipping looks to be around $200 via UPS from Central Ohio to Seattle. It looks like the going rate for one of these is about $600.
Honestly, I think you could find a better deal than from me because the shipping is terrible. |
#10 | |
SCCA T4 - FRS
| The Following User Says Thank You to rice_classic For This Useful Post: | RT-BRZ (05-28-2025) |
#11 | |
I also have a 4.10 that I could probably go ahead and sell too.
#12 |
Drives: Crapcan
I paid between 4-450 for the last two I bought since I have gone back and forth between 4.1 and 4.3 a couple times.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | RT-BRZ (05-30-2025) |
#13 | |
I'm in the middle of some pretty active SCCA regions so I'll probably find a buyer pretty quick. As long as I can break even on what I just bought I'll be happy. |
#14 |
Drives: '22 BRZ
I did 3.73s on mine, no regrets.
| The Following User Says Thank You to DocWalt For This Useful Post: | RT-BRZ (06-03-2025) |
| GR86/BRZ Diff Mounts | Jianlun | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 16 | 06-17-2022 01:25 PM |
| Which is better? Reaplcing rear diff bushings? or installing rear diff brace? | Frs30 | Engine, Exhaust, Transmission | 22 | 04-13-2020 11:23 AM |
| Difference between Whiteline Diff Outrigger Bushings and Diff Cradle kits? | mistople | Engine, Exhaust, Transmission | 10 | 09-21-2018 07:01 PM |
| Diff Mount Inserts install - Diff won't lower??? | ChRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 07-17-2017 01:07 AM |
| Swap AT Diff with MT Diff | sydious | Engine, Exhaust, Transmission | 2 | 03-17-2016 03:59 PM |
