Old 03-07-2025, 06:18 AM   #1
slayed96
Drives: 2020 gr 86
New here, need some advise
I wanna get rid of my torque dip, I was wondering if I should open everything up to 3" or leave it 2.5, and which air intake do yall recommend, I'm gunna get uel headers and a cat back exhaust to go with it.
Sent from my SM-S931W using Tapatalk
slayed96 is offline   Reply With Quote
Old 03-07-2025, 08:11 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Forget the cat back, just get some headers and a tune, done. No intake unless it's connected to a supercharger or turbo, otherwise it's pointless.
The Following 5 Users Say Thank You to DarkPira7e For This Useful Post:
22R (03-07-2025), DAEMANO (03-23-2025), humfrz (03-08-2025), KMA KiCKz (03-07-2025), NoHaveMSG (03-08-2025)
Old 03-07-2025, 01:36 PM   #3
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Aftermarket intake tubes are nice because you can eliminate the cabin sound generator and resonators. When you step on the gas the extra noise makes your car feel faster even if there is no measurable gain.
The Following 2 Users Say Thank You to blsfrs For This Useful Post:
Old 03-07-2025, 03:58 PM   #4
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
Keep the stock airbox and throw in a K&N Filter. There is no need to change to an aftermarket intake since it doesn't do much for gains. You can eliminate the sound generator as it's a simple DIY mod from Home Depot/Lowes. The thread link is below.
https://www.ft86club.com/forums/showthread.php?t=72263
Catback can depend on everyone for sound, unless you're relying on weight reduction, then a single-exit would be beneficial compared to a dual exhaust.
E85, OFT (Open Flash Tablet), UEL, Catback is enough to gain a good amount of power while eliminating the torque dip. If you have the extra $$$ to spend, then I would advise going with the EcuTek over the OFT.
ZC6_STi is offline   Reply With Quote
The Following User Says Thank You to ZC6_STi For This Useful Post:
Old 03-07-2025, 11:47 PM   #5
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
+1 for a header and tune. This will change sound and feel of the car. If you would like to go for the "subie rumble" then go for an unequal length header(UEL).
Catbacks/Axlebacks are usually for sound but will have little gain paired with mentioned above.
+1 for keeping the stock intake. There's been a few posts and some videos on YouTube with dyno testing but take it with a grain of salt.
- My 2015 Scion FR-S OEM+ Build Thread -
TRD | Brembo | RAYS
KMA KiCKz is offline   Reply With Quote
Old 03-08-2025, 02:01 AM   #6
Hello and welcome to ...... The Forum -
Just ignore the so called "torque dip". If you hadn't read about it, chances are you wouldn't even notice it.
Ain't nutten wrong with the machine the way it was designed -
bcj (03-10-2025), Ultramaroon (03-10-2025)
Old 03-08-2025, 06:25 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
You're in Cal. I wouldn't do anything, unless you like putting everything back to stock, including tune, every smog check.
humfrz (03-10-2025)
Old 03-15-2025, 12:23 PM   #8
mrg666
pessimistic skeptic
mrg666's Avatar
It seems you have a 2020 GR86. If GR86 is correct, you don't have torque dip.
The Following User Says Thank You to mrg666 For This Useful Post:
Nails (03-19-2025)
E85 Last min advise? czellers Engine, Exhaust, Transmission 52 02-11-2021 12:53 PM
Advise Please ricky rod Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 37 06-19-2015 05:10 PM
Looking for advise on buying the frs Antairez Scion FR-S / Toyota 86 GT86 General Forum 71 02-11-2015 06:33 PM
FT86 advise please eddiev116 Scion FR-S / Toyota 86 GT86 General Forum 7 02-01-2015 04:13 PM
Relationship advise? Rocket.BRZ Off-Topic Lounge [WARNING: NO POLITICS] 821 07-10-2014 02:43 PM
