Old 09-07-2018, 04:58 PM   #1
mrg666
pessimistic skeptic
mrg666's Avatar
MAF sensor substitute
I have replaced my MAF sensor with Denso 197-6160 which can be found for less than $100 instead of stock sensor (22680AA400). The substitute is working great, fits and looks exactly the same. If it works with my FI engine, it should work with any stock engine as well. Denso 197-6160 is more widely available since it is shared by many Toyota models including Corolla. I bought mine from Amazon for $80. FYI ...
Old 12-26-2024, 06:30 AM   #2
Mykii
Noodleking
Mykii's Avatar
Drives: 2013 Firestorm FRS
Ooh, this is interesting.
I'll have to check it out.
Somehow, my car ended up with a 197-0613 from an Impreza/WRX/Crosstrek.
I'm sure the MAF Scaling is different with this sensor compared to the stock one. I wonder if the Corolla one would have a small adjustment in scaling too.
I just ordered the Toyota part from the dealership to hopefully fix some shizzle in my car, but now i'm curious about this part number.
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
Mykii is offline   Reply With Quote
Old 12-26-2024, 10:55 AM   #3
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
Denso makes the stock sensors, so yeah, the Denso branded part will work the exact same as long as you get the exact one as OEM.
I run the Denso version on my 2004 WRX and it's been 100% fine. People on NASIOC confirmed it was the exact same part. I'm sure it's a similar thing for the BRZ/FRS.
cmiovino is offline   Reply With Quote
Old 01-02-2025, 12:43 AM   #4
Mykii
Noodleking
Mykii's Avatar
I do wonder though. Between 613, 616 and the stock one, I can't tell if the car is working better or worse. I just installed the new OEM one that I got from the dealership. It definitely is dumping less fuel in. My FTLT is almost -20 now, and my FTST is like -5 and the car randomly stutters when holding closer to 3k. I'm probably going to get a revision of my tune because of this just to be safe.
I do wonder if CSG knows if theres any difference in reporting from these models they've seen.
Flex Seal as Dyna-Mat Substitute? MJones_RB Cosmetic Modification (Interior/Exterior/Lighting) 2 06-02-2016 04:13 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 09:11 PM
Substitute tie rod ends 86•BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-22-2013 09:40 AM
Ft-86 Please's Substitute Ft-86 Please Member's Car Journals 11 08-28-2012 05:53 PM
Best MOTOring? Whered it go, is there a substitute? ahausheer Off-Topic Lounge [WARNING: NO POLITICS] 3 03-26-2012 12:54 AM
