#295 | |
For me anyway it's more about having something functional rather than fake, so even if it could be done without the snorkel part I think it could still work and likely help at least some heat escape, but at a minimum wouldn't be just for aesthetics. |
| The Following User Says Thank You to ThatYeti For This Useful Post: | Wally86 (12-06-2023) |
#296 |
Drives: Orange FR-S
Trunk pull
Probably helps if I include the STL for the trunk pull upthread.
Things you need:
#297 |
Drives: '22 BRZ
Designed an intake snorkel like the GR Cup cars. No clue if it fits first gens, *should* fit second gens but haven't had a chance to pull my bumper and triple check my work. It fits the airbox fine anyway, with a bit of weather seal tape.
I designed it to maximize the air intake area into the box while still using thin foam weatherstripping (1/16" thick) and mounting using the OEM grommet. STL here: https://drive.google.com/drive/folde...9X?usp=sharing ![]() ![]() ![]()
#298 |
Drives: Fr-s
I only printed the gurney flap to add to the off the shelf vent, but the end result is a bit similar.
![]() It's split into 3 pieces, the outers hold down the center section. ![]() Printed some blanks for the turn signals ![]() I needed a cover for the A/C.
| The Following 4 Users Say Thank You to redlined600 For This Useful Post: |
#299 | |
Drives: Toyota 86
The clean one is the second gen.
| The Following 2 Users Say Thank You to makinen For This Useful Post: | DocWalt (01-26-2024), RedReplicant (01-28-2024) |
#300 |
Drives: Turbocharged 2015 Subaru BRZ
| The Following 4 Users Say Thank You to DatChinchilla For This Useful Post: |
#301 |
First 86 Driver Baby!
Drives: FR-S, Flex
Recently picked up a Elegoo Neptune 4 Max with the intent to make car parts, I’m still new to the 3D printer world so following this thread for inspiration!
| The Following User Says Thank You to kmbkk For This Useful Post: | Wally86 (02-19-2024) |
#302 |
Drives: 2014 Scion FR-S
Wanted to share my progress on a custom intake tube for my turbo. 3D scanned the area using photogrammetry (3D zephyr exported to 3ds max).
![]() ![]() Then used Solidworks to create the final model ![]() Printed a few prototypes in thin-walled PLA before final one in ABS ![]() Printed in ABS then acetone vapor smoothed ![]() Here it is installed ![]() This picture was taken before the acetone vapor smoothing process
#303 |
Driver
Drives: Firestorm Red 2013 FR-S
Emblem / Badge
I spent a whole weekend making this near-perfect emblem.
It'd make my day to see someone else using it...![]() ![]() ![]() Link: https://makerworld.com/en/models/149...ofileId-162918 |
#304 | |
Be Kind
Drives: 2020 86
#305 | |
Drives: Toyota 86
#307 |
Drives: '22 BRZ
This is definitely the coolest car project I've done yet, IMO. I designed new rear swaybar mounts to correct the rear swaybar geometry when lowered and stiffen the mounts. I sent the design off to be 3D printed in aluminum and they arrived today. The whole process was great, the printer communicated with me the whole time and confirmed some aspects of my design. For example, they 3D printed the threads into the mount so I didn't have to tap the holes. So cool!
![]() ![]() The design ended up being perfect and everything went together smoothly. ![]() This is the stock geometry, you can see how the swaybar isn't perpendicular to the end link or the ground but it's also not centered on the control arm so it can torque the arm. ![]() My design fixes that ![]()
| The Following 5 Users Say Thank You to DocWalt For This Useful Post: | bcj (12-10-2024), Dadhawk (09-15-2025), Drifter X (01-08-2025), Jdmjunkie (12-13-2024), Racecomp Engineering (12-10-2024) |
#308 |
Drives: '22 BRZ
Designed and printed some stuff inspired by @makinen and his prints.
Battery adapter for my Noco NLP20: ![]() Snazzy looking door mirror "wing" to help with buffeting: ![]()
| Official DTM Autobody Services Thread for FT86Club! | DTMAUTOBODY | Southern California | 9 | 12-31-2013 03:09 PM |
| Official FT86Club Chatroom? | wrxgoose | Site Announcements / Questions / Issues | 13 | 09-15-2012 06:26 PM |
| Official FT86Club decal idea? | Hanzo | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 06-21-2012 09:09 PM |
