Old 10-12-2023, 11:15 AM   #1
Howaitoguru
Howaitoguru's Avatar
Drives: 2016 Subaru BRZ
Does this sound like clutch chatter?
So this is my 3rd clutch I’m at 108k miles I got a southbend stage 2. Before I had an ACT Street kit. And before that was stock. I can’t tell if this is normal clutch chatter or if it’s TOB noise. https://streamable.com/9fn8fj
Howaitoguru is offline   Reply With Quote
Old 10-12-2023, 11:28 AM   #2
Joveen
Joveen's Avatar
Drives: Bone stock
It doesn't really sound like it. Do you have the same sound at idle?
Sent from my SM-F936U1 using Tapatalk
Joveen is offline   Reply With Quote
Old 10-12-2023, 11:45 AM   #3
Howaitoguru
Nope. Just when I drive. As soon as I push the clutch in it goes away. I just hope i don’t have to replace it again.
Old 10-12-2023, 11:54 AM   #4
Joveen
Joveen's Avatar
Drives: Bone stock
Might be throwout bearing fam.
Old 10-12-2023, 11:55 AM   #5
Howaitoguru
I’m going to be pissed this will be the 3rd time I have to replace it due to TOB
Old 10-12-2023, 12:07 PM   #6
Tokay444
Did you replace the front bearing retaining cover at either of the 2 other clutch jobs?
Old 10-12-2023, 12:36 PM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
If you could, try to get a better recording of the sound. Maybe I'm old and my hearing ain't what it used to be, but I couldn't hear anything other than engine and air noise.
Also, a bad TOB usually makes the most noise with the clutch pedal depressed.
blsfrs is online now   Reply With Quote
Old 10-12-2023, 04:29 PM   #8
Howaitoguru
A shop did it so not sure.
Old 10-12-2023, 04:30 PM   #9
Tokay444
Is it on your receipt of parts?
Old 10-12-2023, 04:32 PM   #10
Howaitoguru
Unfortunately my car has catless headers and a catback exhaust so it’s going to be loud. The only way I can make the noise is when driving. It doesn’t make it at idle. It kind of sounds like rattling kind of like a maraca which makes me think it’s just clutch chatter but idk. It also only happens in higher gears.
The Following User Says Thank You to Howaitoguru For This Useful Post:
blsfrs (10-13-2023)
Old 10-12-2023, 05:29 PM   #11
Howaitoguru
Flywheel, release arm spring, Release Brg. Clip, that’s it. Says Remove and replace clutch, customer has aftermarket flywheel, clutch fork, and pivot, inspect upon removal. Replace if necessary. The one before that says remove and replace clutch, clutch fork, pivot and springs, and flywheel. Has the same parts. I currently have a Stage 2 Daily kit from south bend.
Old 10-12-2023, 05:54 PM   #12
Tokay444
Sounds like 3rd time will be the charm then.
Old 10-12-2023, 05:55 PM   #13
Tokay444
How many headers you manage to get on there?
Old 10-12-2023, 05:57 PM   #14
Howaitoguru
Are you trolling?
Clutch chatter or nah? kt45 Issues | Warranty | Recalls / TSB 2 10-09-2016 01:27 AM
Clutch chatter brzydk Engine, Exhaust, Transmission 7 10-05-2016 01:31 PM
Bad Idle, stalling, clutch chatter, gear lockout, failed clutches: My story and fix Pneub Engine, Exhaust, Transmission 11 08-05-2016 11:29 AM
Clutch, LW flywheel and chatter.... wootwoot Engine, Exhaust, Transmission 20 11-17-2014 04:50 PM
Clutch Chatter & Traction Control? Fortney Issues | Warranty | Recalls / TSB 9 10-24-2012 12:43 AM
