Drives: 2013 frs base
Energy Suspension Shifter bushing
Has anyone tried to install this brand of rear shifter bushing? I could not get the thing to slide onto the shifter rod even with dish soap as a lubricant.
In videos of other brands, the thing seems to slide on with minimal effort. Energy Suspension is going to send me some of their special lube, but any other suggestions would be appreciated. |
#2 |
Drives: 2018 BRZ
Transmission in neutral and parking brake released? I struggled for half an hour until I realized that.
#3 |
Drives: '22 BRZ
I didn't use that brand, but I found it easiest to lube it up, sort of jam it between the shifter bracket and body, then bench press the shifter bracket up into place which pushed the bushing onto the bracket.
I couldn't get enough force into to push it onto the bracket otherwise.
#4 |
Thank you these ideas but I'm not understanding either of them.
The rod and bushing are horizontal so I can't make sense of the bench press scenario and I don't see what influence the parking brake will have. Energy Suspension is sending their grease and suggested heat the bushing with a blow dryer. |
#5 |
Drives: 2018 BRZ
I'll ask again, is the transmission in neutral and parking brake released? If not you won't have enough room to slide the bushing on, no matter how much lube you use. It will feel like it can't go on, but that's just due to misalignment between the shifter carrier shaft and the transmission tunnel and driveshaft. Note that leaving the transmission in gear and having the parking brake engaged doesn't interfere with removing the stock bushing.
#6 | |
#7 |
Drives: 2018 BRZ
Interesting. So I guess the different makes do make a difference. This concludes my usefulness here. Best of luck with your problem.
| The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | blsfrs (09-27-2023) |
#8 | |
Drives: '22 BRZ
When you remove the bushing, the bracket assembly can swing down a bit. Grease up the bushing and place it on the end of the bracket. Push the bracket upwards and the sloped rear end of the tunnel will push the bushing onto the bracket. I'm not sure how else to explain it. Are you sure you're installing the bushing right side up?
| The Following User Says Thank You to DocWalt For This Useful Post: | blsfrs (09-27-2023) |
#9 |
Thanks guys. I'll give it another shot this weekend and let you know how it goes.
#10 |
Drives: '22 BRZ
FWIW it was *not* easy at all, definitely harder than I expected.
#11 |
Ned flanders
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
Yeah I just did this, it takes some great force to get it past that first "wall". Did it with a lift and it still kicked my butt a little
797Performance.com
| The Following User Says Thank You to nickmerronesucks For This Useful Post: | blsfrs (09-30-2023) |
#12 |
Drives: 15 Impreza
Is the shifter bushing a worthwhile modification? I've changed it out on other subarus but was under the impression it didn't make a huge difference on these cars.
| The Following User Says Thank You to cueball89 For This Useful Post: | blsfrs (10-01-2023) |
#13 | |
Drives: 2018 BRZ
I will say that I find replacement bushings and inserts for the transmission and differential to be very noticeable, eliminating all the movement of the shifter. I was unhappy with the amount of slop and lash it had stock, particularly when letting off the gas in lower gears and higher engine RPM. I did most (if not all) drivetrain bushings (except engine mounts) and am very pleased with the result, but it wasn't until the last mod that it really made a big difference. It might be that the last one (the diff bushings) are the important ones, or that all the bushings/inserts are needed together. I did Perrin rear bushing, Whiteline front insert, Torque Solutions front carrier bushings, Whiteline rear subframe inserts and Whiteline diff inserts. |
| The Following 3 Users Say Thank You to Ohio Enthusiast For This Useful Post: |
#14 | |
Drives: 15 Impreza
Agreed, those bushings and inserts make a huge difference. Rear subframe, rear diff and transmission insert are what I've done. I'd like to get some stiffer engine mounts in the future. |
| FS: Energy Suspension Rack And Pinion Mount Bushing Set | Jtrem | Brakes, Suspension, Chassis | 1 | 02-26-2018 12:04 AM |
| Energy Suspension front arm bushing kit | Satanasso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 02-08-2017 09:56 AM |
| FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing | bergy | Transmission and Driveline | 8 | 10-20-2016 10:57 PM |
| Perrin Shifter Bushing rebranded Energy Suspension? | BRZach | Engine, Exhaust, Transmission | 10 | 01-12-2016 03:17 PM |
| Whiteline transmission bushing and Perrin shifter bushing review. | Superhatch | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 12-09-2012 09:40 PM |
