Old 08-31-2023, 03:07 PM   #15
Timeserts are also good. Just keep in mind it is really important you drill and tap the threads needed for the repair insert straight or you are going to have problems. Especially a bolt that long.
+1 Straight hole and tap are critical. If the tap is started crooked, game over.
Old 08-31-2023, 04:29 PM   #16
Jozy
Jozy's Avatar
Drives: 2015 Subaru Brz Limited
That metal plate betweent the starter and the bolt entry point. I'm guessing that's a ground for the harnesses so without that pressed against the block the car will probably not start or have other issues?
Jozy is offline   Reply With Quote
Old 08-31-2023, 04:32 PM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I can't visualize this right now. I will take a look when I get home, or maybe someone else can answer this before hand.
Old 09-01-2023, 09:58 AM   #18
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
I've never fixed threads before. If I go that route do I need to up from a 1.25 to a 1.50 or what's the best way to go about that?
I looked into the heli coil and got even more confused ��
Not hard to do. A couple of years ago, I stripped out the threads for a timing belt idler on an ej.
There wasn't enough room for a drill. I used a "T" handle on the drill bit and was able to bore out the hole manually. Aluminum is soft so it wasn't too difficult. Tapped it, screwed in the coil, and was good to go.
You don't have to worry too much about getting the hole straight because the existing hole is already straight.
The Following User Says Thank You to blsfrs For This Useful Post:
Ultramaroon (09-01-2023)
Old 09-01-2023, 02:07 PM   #19
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I had a friend strip a cam cap thread on an EJ25 and he got the helicoil off using the existing hole. Was not a fun repair. I can't remember what insert I used to fix it but it was just big enough OD to work. The cam cap bolts on the EJ have a tapered shank so it was super important that it was perpendicular to the head. I have a tap guide block somewhere that I used to fix it.
blsfrs (09-01-2023)
Starter button gcranston Interior Parts (Incl. Lighting) 4 08-17-2022 03:13 PM
Starter swap? Wil Engine, Exhaust, Transmission 1 07-27-2016 08:50 AM
2013 BRZ replacement starter, correct part help sftateofmind Issues | Warranty | Recalls / TSB 25 07-21-2016 11:12 PM
ONR Starter Kits u/Josh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 11-05-2013 12:47 PM
self-starter jarviz Engine, Exhaust, Transmission 16 09-15-2012 12:45 AM
