Old 08-22-2023, 12:15 PM   #15
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Torque to yield.
Dude, give yer lugs a tug and see if they're still attached.
The Following 2 Users Say Thank You to bcj For This Useful Post:
soundman98 (08-23-2023), Ultramaroon (08-22-2023)
Old 08-22-2023, 01:27 PM   #16
Originally Posted by WNDSRFR View Post
Yes I agree.
And you should change lug nuts every time you remove them.
Lug nuts are designed for reuse. It would be wasteful to install new ones each time a wheel is removed.
Old 08-22-2023, 01:44 PM   #17
WNDSRFR
Drives: FR-S,GTI
I agree.
Most lugnuts are designed to be reused.
I'm not too sure about the lugnuts that come on a '13 FR-S.
I've had ALOT more problems with used lugnuts than used drain plugs.
Greddy Magnetic Oil Drain Plug + 10 Gaskets skylinekin Engine, Exhaust, Bolt-Ons 0 12-27-2017 05:21 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 08:36 PM
Best magnetic drain plug? FR-Sizzle Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 09-28-2015 02:07 PM
Magnetic oil drain plug, effective? BRZPDX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 7 02-17-2013 12:59 AM
Greedy Magnetic Drain Plug USMC -FRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 02-10-2013 07:04 PM
