Old 08-11-2023, 12:05 AM   #15
Pat
Pat's Avatar
Drives: 2023 BRZ
Is that cause for concern?
Sent from my Pixel 7a using Tapatalk
Old 08-11-2023, 12:16 AM   #16
DarkSunrise
DarkSunrise's Avatar
Still better than the 30 psi or less that have been seen with non-aero, sx2 cars at Thunderhill.
Speaking of which, @Ansix Auto, what was the tire, suspension and aero setup on the car in the video?
2022 BRZ Build
2013 FR-S Build
Old 08-11-2023, 12:25 AM   #17
Ansix Auto
FT86Club Official Vendor
Drives: 2023 BRZ
At 40psi we’re not concerned at all. I’ll upload a video tomorrow of some data where it dropped below 20psi. This was before we made the changes to address the issue directly.
255 RE71Rs
KW V4 with higher rates
Front lip, canards and rear wing at the steepest setting with a gurney flap.
Check out our GR86 and BRZ products!
https://ansixauto.com/subaru/
Ansix Auto is offline   Reply With Quote
The Following User Says Thank You to Ansix Auto For This Useful Post:
DarkSunrise (08-11-2023)
Old 08-11-2023, 10:01 AM   #18
JimV
Drives: FRS
Very interested on all of the oiling mods done to the car in the video. High 30s low 40s would be a considerable improvement versus the low 20s people have been seeing.
JimV is offline   Reply With Quote
Old 08-11-2023, 11:38 AM   #19
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
Nice! Thanks for sharing! Looking forward to your setup and some comparisons!
Have you chatted with @900BRZ? Would be cool to see a collab/independent verification.
nissanfanatic is offline   Reply With Quote
Old 08-11-2023, 11:52 AM   #20
Ansix Auto
Drives: 2023 BRZ
We have not talked with @900BRZ. Once we release our findings, he’s more than welcome to make the same modifications.
Old 08-11-2023, 02:21 PM   #21
Ansix Auto
Drives: 2023 BRZ
Here's an onboard lap with our 2023 Subaru BRZ at the Ridge Motorsports Park. Here you can see that before addressing our oiling issues, we see the oil pressure drop below 20psi on multiple occasions.
Old 08-11-2023, 10:21 PM   #22
Lucky Ookami
Lucky Ookami's Avatar
Drives: N/A
Which wing is that?
Lucky Ookami is offline   Reply With Quote
Old 08-12-2023, 05:28 PM   #23
gnarjunkie
Drives: '23 GR86, '17 BRZ
Have you tracked it and collected data after applying your oiling fixes?
gnarjunkie is offline   Reply With Quote
Old 08-14-2023, 03:40 AM   #24
bkd705
Drives: 2023 BRZ WRB
In your before video it looks like the pressure drops from around 45 to around 20ish, and in the second from 65ish to 45ish so similar pressure drops but just a higher overall baseline?
Is this correct or am I misunderstanding the data?
2023 World Rally Blue BRZ | Previously 2021 M2C - 2018 BMW M2
bkd705 is offline   Reply With Quote
Old 08-14-2023, 05:07 PM   #25
Ansix Auto
Drives: 2023 BRZ
Originally Posted by Lucky Ookami View Post
Which wing is that?
It's a ADRO rep with custom end plates.
Yes we have, the video is on the previous page.
The baseline isn't that same, that's correct. We addressed a few issues at the same time. One was the low overall baseline pressure, the other was the pressure drops. The lowest we saw before the changes was about 12psi, not 20ish.
Old 08-14-2023, 05:57 PM   #26
gnarjunkie
Ah, I see that now. I had misunderstood.
That's great -- eagerly waiting to hear what you did to mitigate the issue (and hoping it wasn't adding an Accusump )
Old 08-14-2023, 10:04 PM   #27
bkd705
Ah I see, yeah apologies I missed that drop from the "before" video.
Any plans to release the data aside from just the videos? Would be curious to see the duration of the drops and compare the exact numbers, a bit hard to view on just video.
I see on your site you guys sell a baffle pan, is that part of the solution in the "after" video?
Thanks!
GoPro Mount - Ansix Auto Ansix Auto Interior Parts (Incl. Lighting) 7 04-30-2025 12:51 AM
2022+ BRZ/GR86 CANbus Adapter - Ansix Auto Ansix Auto Audio/Visual, Electronics, Infotainment, NAV 11 07-04-2023 04:01 PM
Element Fire Extinguisher w/ Mount - Ansix Auto Ansix Auto Interior Parts (Incl. Lighting) 17 01-17-2023 03:20 PM
2022+ BRZ/GR86 Oil Pan RTV Solution - Ansix Auto Ansix Auto Engine, Exhaust, Bolt-Ons 1 11-28-2022 05:02 PM
2022+ BRZ/GR86 FA24 Oil Pan Baffle - Ansix Auto Ansix Auto Engine, Exhaust, Bolt-Ons 0 11-18-2022 05:15 PM
