Old 08-06-2023, 06:08 PM   #1
PTrain
Drives: 2014 FRS
Ecutek no useful data
Just checking to see if this is unique to my car or if others have run into the same issue. Plugging in my ecutek dongle and loading up their app I can connect no problems but basically none of the info is useful. I can get rpm and inconsequential things like if the ac compressor is on but nothing useful like IAT, MAP, any fluid temps, nothing.
PTrain is offline   Reply With Quote
Old 08-07-2023, 07:52 AM   #2
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Do you have an ecutek license on the car? Has it been tuned?
Old 08-07-2023, 09:24 AM   #3
PTrain
Drives: 2014 FRS
Yep and yep.
Old 08-07-2023, 10:10 AM   #4
dragoontwo
dragoontwo's Avatar
Are you connecting it directly to the port or using an OBD extender? The port pins are known to become loose and cause issues.
Old 08-07-2023, 11:01 AM   #5
PTrain
Drives: 2014 FRS
I’m connecting it directly to the port. I also tried connecting my LM-2 and was able to at least pull up IAT, didn’t try any other values yet.
Old 08-07-2023, 11:05 AM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Can you show us a screenshot of your window with Ecutek on it?
Old 08-07-2023, 05:48 PM   #7
CSG Mike
CSG Mike's Avatar
Have you gone through the parameter list and checked off the ones you want?
RToyo86 (08-08-2023)
Old 08-07-2023, 09:44 PM   #8
PTrain
Drives: 2014 FRS
Well I feel like an idiot. As you'll see stuff like IAT is in red so I just assumed you couldn't select it. Turns out that is not the case. I'm not really sure why it's red but I can put it on the dashboard now.
Old 08-08-2023, 07:35 AM   #9
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
Seems strange
You don't get full set of data unless it's ecutek tune.
Make sure your on latest ecutek app and that you let the blutooth dongle update
Also you need ecutek racerom 9 or higher patch on tune for ecutek app to work
Also instead of going to dash display try going to data logging and see if all parameters are there and make sure your not in demo mode
AussieBRZ is offline   Reply With Quote
Need help with Ecutek programming and data logging stlgrym3 Southern California 0 08-10-2018 02:58 PM
data logging issues on ecutek. disconnection from obd Astroboy Issues | Warranty | Recalls / TSB 1 08-20-2017 09:11 AM
ECUtek data logging problems Iwannajag Software Tuning 3 06-12-2016 12:45 AM
Lack of tuning data due to ECUtek? 350matt Software Tuning 37 12-08-2013 01:19 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 01:55 PM
