Old 07-17-2023, 03:18 PM   #29
Arthur-A
Arthur-A's Avatar
Drives: 2020 BRZ/86, 2020 BMW 330i
"B...bUt MaNuAl SaYs.."
Arthur-A is offline   Reply With Quote
The Following 2 Users Say Thank You to Arthur-A For This Useful Post:
Jdmjunkie (07-17-2023), Tokay444 (07-17-2023)
Old 07-17-2023, 03:26 PM   #30
Tokay444
tHe MaNuFcTeR nOs BeSt
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
Arthur-A (07-17-2023), Jdmjunkie (07-17-2023)
Old 07-17-2023, 07:25 PM   #31
Originally Posted by Tokay444 View Post
You think they designed it on 0w20? LOL The 0w20 is ONLY in the crank case to meet the EPA mandated fuel economy numbers. Not because it protects the engine better, because it doesn't.
Yes, it WAS designed for 0w20. You put that shit into an engine not designed for it and see how it responds. While I agree that thicker oil did not cause this failure, There's still a good argument for controlling engine oil temperature for the sake of shedding heat from the internals. I argue that engines designed to operate using thin lubes may be more vulnerable to physical distortion brought on by wide thermal gradients and high operating temperatures in general.
Just because the oil can maintain viscosity at 300 F doesn't necessarily mean it's ok for the rest of the engine to be operated like that.
NoHaveMSG (07-17-2023)
Old 07-17-2023, 09:32 PM   #32
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Dry sump is the answer.
Dry sump so expensive though
Dzmitry (07-20-2023)
Old 07-17-2023, 10:11 PM   #33
NoHaveMSG (07-17-2023), Teseo (07-18-2023)
Old 07-17-2023, 10:39 PM   #34
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
What's fun to consider is that a Ford 6.8 V10 in an E350 has "5W20" on the filler cap, while the same 6.8 V10 in an E450 incomplete chassis has 5W30. I'd wager the main difference between those two applications is how they fit in the CAFE rulebook.
Any engine I come across with an iffy oil spec that reeks of EPA I disregard. Ford modulars get 5W30, HEMIs get 5W30, the pentatrash 3.6 V6 was born with 5W30 and was later moved to 5W20. You can bet your ass I put 5W30 in it when that engine is in anything heavier than a caravan, like a ram or promaster.
And my 86 gets Motul 5W30 in summer. Still gets 0W20 in winter though because I go down to almost -30 degrees celcius.
The Following 5 Users Say Thank You to RZNT4R For This Useful Post:
Arthur-A (07-17-2023), Jdmjunkie (07-17-2023), Teseo (07-18-2023), Tokay444 (07-18-2023), ZDan (07-18-2023)
Old 07-18-2023, 09:16 AM   #35
Tokay444
Also consider that a Coyote GT standard model specs 5w-20, but opt for the Track Pack, and the identical engine calls for 5w-50. Not just at the track. All the time. Look at the factory service manual and what the spec is on all the bearing clearances and compare them to ours...
I've run 0w40 daily, year round, in Canadian winters, and on track at Mosport, Cayuga, Grand Bend, Shannonville, Road Atlanta and Road America, no oil cooler, with R-comps, TRD sway bars, and RCE Tarmac 2(coilovers for only 1 summer. BRZ tS dampers and TRD springs from day 1) for over 255,000 KMS. Not once has my car ever had an oil related issue. It's never overheated. You'll not catch me letting the EPA dictate how to protect my engine. It's never gone into limp mode. In fact, the only thing that ever has happened beyond scheduled maintenance and wear items was an OE battery went dead, and two Toyota dealership batteries exploded back to back within weeks of each other. No issue since switching to an Optima Yellow Top 3 years ago.
The Following 8 Users Say Thank You to Tokay444 For This Useful Post:
Arthur-A (07-18-2023), MrSkubi (07-26-2023), new2subaru (07-18-2023), nomtimesthree (07-18-2023), RZNT4R (07-18-2023), Teseo (07-18-2023), ZDan (07-18-2023)
Old 07-18-2023, 09:36 AM   #36
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Anybody installed and tested Killer B's solution?
Old 07-18-2023, 09:51 AM   #37
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
There is an active thread which has track testing with some of their beta products. Intial results suggest further development is still needed.
The Following 3 Users Say Thank You to RToyo86 For This Useful Post:
blsfrs (07-18-2023), Teseo (07-18-2023), ZDan (07-18-2023)
Old 07-23-2023, 07:36 AM   #38
ZDan
ZDan's Avatar
Drives: '23 BRZ
There's this:
The Following 2 Users Say Thank You to ZDan For This Useful Post:
blsfrs (07-23-2023), RZNT4R (07-23-2023)
Old 07-23-2023, 08:31 AM   #39
RZNT4R
That's a nice install, and configured like that, accumulator only with a manual valve, is probably pretty cheap and more than enough for the very momentary dips that are being seen.
The Following User Says Thank You to RZNT4R For This Useful Post:
blsfrs (07-23-2023)
Old 07-23-2023, 11:37 AM   #40
blsfrs
blsfrs's Avatar
What air psi are you starting at?
Old 07-23-2023, 12:48 PM   #41
ZDan
ZDan's Avatar
Drives: '23 BRZ
This is not my setup, somebody posted this up on f-book. If I go this route I'll probably go with 7psi or whatever the lowest recommendation is.
blsfrs (07-23-2023)
Old 07-23-2023, 01:27 PM   #42
RZNT4R
lowest recommended pressure
Moroso has a different idea with their accumulator
more precharge wil yield less volume, but less pressure drop as that volume is supplied. The good thing about such a system is it would be easy to precharge at a higher pressure to account for instantaneous pressure drops at a track with short corners, but if you hit a track with a long sweeper, drop the precharge a bit to trade pressure for volume.
Someone in the comments even set it up for the best of both worlds: an aux air tank for a lower precharge yielding sustained pressure AND greater oil volume.
[edit]
The picture looks like a canadian brethen, what with the big "AVERTISSEMENT" sticker on the brake booster.
Engine failure michael_basden Member's Car Journals 5 10-06-2018 06:58 PM
Engine failure Geex Issues | Warranty | Recalls / TSB 19 07-01-2018 04:57 PM
Engine failure! mackeye Engine, Exhaust, Transmission 24 01-30-2018 12:48 AM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 03:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
