Drives: 2015 BRZ
Check Engine Light After Replacing Flat Tire
2015 BRZ - I got a flat tire on my left rear, threw on the spare and of course the Traction, ABS, and Check Engine lights were all on. Limped to the tire shop and replaced all 4 tires with new ones. Traction and ABS lights cleared a few yards after leaving the shop but the Check Engine light is still on. The engine seems to be running normally. Is this something I can clear myself or do I need to take it some place?
Thanks! |
#2 |
Rust bucket enthusiast
If we don't know what it's for, we can't tell you. Go to an automotive shop and ask them to read the code. It's likely benign; can be cleared and forgotten
#3 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Codes. Always start with codes. The check engine light alone can be any one of about 170 error codes.
#4 |
Be Kind
Drives: 2020 86
Free: auto parts store OBD scan
Cheap: amazon OBD code scanner (DIY) Not as cheap: local mechanic shop OBD scan Not cheap a tall: dealer OBD scan
#5 |
Drives: 2015 BRZ
Thanks everyone, the code is a P2158 Speed Sensor B.
** Edit: The check engine light only came on after putting the spare on. I had to drive a little on the flat to get off the highway and that didn't trigger the light. So I'm wondering if this should eventually clear on its own, or if it needs to be cleared manually, or if the actual sensor is damaged. Last edited by Super Wabbit; 06-19-2023 at 04:55 PM. |
#6 |
Drives: 2013 frs base
Try disconnecting the battery for 30 seconds. Or buy a code reader. I have an older Subaru (in addition to my FRS) so having a code reader is mandatory.
| The Following User Says Thank You to blsfrs For This Useful Post: | humfrz (06-22-2023) |
#7 |
Drives: 2015 BRZ
I've got a code reader now, so it's safe enough to try erasing it and seeing if it comes back?
#8 |
Clear it and be done. Also read the manual, you never put the spare on the rear of a BRZ.
| The Following User Says Thank You to Grady For This Useful Post: | blsfrs (06-19-2023) |
#9 |
#10 |
Drives: 2015 BRZ
Cleared the code, engine seemed underpowered for a few miles but then went back to normal. No bode in about 100 miles. Thanks for the help everyone.
| Check engine light then a traction control light then just a check engine... and then | Jstyle | Issues | Warranty | Recalls / TSB | 13 | 02-15-2021 06:10 PM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 10:39 AM |
| Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 07:06 AM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 07:16 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 07:50 AM |
