Old 04-07-2023, 03:28 PM   #1
callisto
Drives: 2019 Subaru BRZ
Subaru's OEM wideband front O2 sensor table (10.14 AFR) for any intake
Hi all, I've been decoding the red intake ECUs and one of the cool things I found is that Subaru has rescaled the Front O2 sensor down to 10.14 AFR. I know the community was trying to work out this rescaling a few years ago with black intake vehicles (which were limited to 12.17 AFR), and since both use the same front O2 sensor, that seems useful to share. So here's what Subaru thinks a wideband scaling should look like for gen1 (K00G black intake, S10C red intake) Front Oxygen Sensor Scaling A/B.
EDIT: See tomm's comment below; Ecutek may have a better-scaled table, and there's other threads on this forum discussing that scaling years ago as well. This may not be the best scaling, but any of them is going to be an improvement over what shipped in 2012.
callisto is online now   Reply With Quote
The Following User Says Thank You to callisto For This Useful Post:
DocWalt (11-30-2023)
Old 04-07-2023, 05:13 PM   #2
tomm.brz
Drives: brz 2017 hksv2
they updated it in 2017 because they implemented full time closed loop fueling in non-euro tunes
in Euro tunes they implemented it in 2018 with Q00G calibration
anyway any tuner is rescaling the lambda since the beginning.. oft tunes have it rescaled to
Subaru scaling anyway is still a bit off compared to real life values, when you get to compare it to a wideband aftermarket sensor you see it s pretty off
Ecutek gives a pretty good rescaling to use that is more precise in their pdf files
Old 04-07-2023, 05:57 PM   #3
callisto
Hmm, I'll have to look into that, but as I don't have Ecutek I'm not sure I have access to those. Thanks for the tip!
Old 04-07-2023, 06:13 PM   #4
tomm.brz
easy to find them Also in google
callisto (04-07-2023)
Old 11-14-2023, 10:31 PM   #5
jamie0404
Drives: Toyota
Originally Posted by callisto View Post
Hi all, I've been decoding the red intake ECUs and one of the cool things I found is that Subaru has rescaled the Front O2 sensor down to 10.14 AFR. I know the community was trying to work out this rescaling a few years ago with black intake vehicles (which were limited to 12.17 AFR), and since both use the same front O2 sensor, that seems useful to share. So here's what Subaru thinks a wideband scaling should look like for gen1 (K00G black intake, S10C red intake) Front Oxygen Sensor Scaling A/B. fnf
The best way to determine which scaling method is best for your car is to experiment and see which one gives you the best results.
jamie0404 is offline   Reply With Quote
Old 11-15-2023, 12:02 PM   #6
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
So why don't you share with us your experimentation efforts? We're really interested in learning from your vast knowledge on the subject....
...Reported
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
x808drifter (11-16-2023)
Old 11-15-2023, 12:06 PM   #7
callisto
I’m working on a different project than the usual max-perf tuning, call it stock-plus if you like, but in this specific case I’d never seen the official 17-20 sensor scale posted, so I shared it. If you have a tune or a dyno you can in theory get better outcomes than stock, so go for it!
Old 11-15-2023, 04:58 PM   #8
AussieBRZ
AussieBRZ's Avatar
Drives: WRB BRZ
I've used this scaling here on all cars 2012-2021
Works well
https://www.ft86club.com/forums/showthread.php?t=82875
AussieBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to AussieBRZ For This Useful Post:
callisto (11-15-2023), DocWalt (11-30-2023)
wideband 02 sensor + ECU Longuy Software Tuning 2 05-06-2022 11:19 AM
Wideband sensor tofurun Engine, Exhaust, Transmission 2 02-11-2017 10:42 AM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Where does wideband O2 sensor go? Turbowned Forced Induction 8 08-29-2014 02:16 PM
LC-1 wideband 02 sensor MattF Engine, Exhaust, Bolt-Ons 4 11-05-2013 09:52 PM
