Old 02-06-2023, 04:40 PM   #1
JohnGT86-Uk
Drives: 2017 GT 86
Fuel Pressure Way Too High Issue On Idle
Hello all!
After having my engine rebuilt I have been having issues starting the car..
We have come to the conclusion it is fuel related on the high pressure side,
High pressure target on idle is roughly 580 Psi
High pressure actual on idle is over 2000 Psi !!
Car only runs with the fuel pressure sensor unplugged, it idles perfectly like this.
Do you think its a faulty fuel pressure sensor or anything else?
currently a OEM sensor is on b/o so would like to test other stuff while I'm waiting for it to arrive
Thanks
JohnGT86-Uk is offline   Reply With Quote
Old 02-06-2023, 05:53 PM   #2
Tokay444
Replace sensor and report back.
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
Grady (02-06-2023), x808drifter (02-09-2023)
Old 02-06-2023, 06:36 PM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Static test from the manual. Pin 1 is ground, apply 5vdc to pin 3. Vout on pin 2 should be .5vdc.
Old 02-06-2023, 08:32 PM   #4
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Sanity check: What does it read with the pressure relieved?
When it runs and the pressure is too high, what does the spill valve actuation look like?
The Following 3 Users Say Thank You to RZNT4R For This Useful Post:
NoHaveMSG (02-06-2023), Ultramaroon (02-07-2023), x808drifter (02-09-2023)
Old 02-06-2023, 08:49 PM   #5
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Well that just makes more sense and sounds easier.
High Pressure Fuel Pump and Aftermarket Headers NRXRaptor Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 03-28-2021 04:23 PM
High pressure fuel pump resistance? sid94 Engine, Exhaust, Transmission 0 03-22-2018 08:54 PM
high pressure fuel pump = 5 years / 100 000 km ? jefars Issues | Warranty | Recalls / TSB 7 09-16-2016 02:26 PM
High Pressure Fuel Pump Thread crazyfrenchbiker Engine, Exhaust, Transmission 10 09-09-2015 02:32 AM
Idle issue then Fuel Cut SupraFly85 Issues | Warranty | Recalls / TSB 4 10-19-2013 11:26 PM
