Tjae
Drives: 2014 Scion FRS Black
Hello I have a 2014 Scion FRS with with an engine swap .
After completing engine swap and getting everything checked at a shop the car seemed ready to go . After driving it home I smelt a burning smell and there was smoke come up from passenger side of engine bay, I suspected the cam plate may still have a minor leak . However the smoke is WHITE and I read blue means oil. The smoke I hope seems to be coming from something burning off the exhaust manifold Yesterday 1/25/23 I drove the car again and same thing happened , so when I got home I turned on car and left it idle as I walked dog in the yard nearby to see if the smoke would come. It doesn’t show up when idle at least not within 20 mins, the smoke only appear when I drive the car at moderate speeds like 40-50 mph. My assumption was the cam plate may still be leaking but when I rub a napkin down there I see no oil (it was leaking past but shop said they fixed it) . My next guess is maybe there is residue left over on exhaust someway somehow and it’s burning off or worse case scenario It may be coming from something else like the timing cover even tho I don’t feel it. Taking it back to shop tomorrow and they said they will try to see what’s causing it. TL;DR: I just want to drive car, it’s been out of commission for around 8 months and I finally put the money down to get everything installed and everything seems fine until I drive and I see the white smoke and burning smell from engine bay in the left side. EDIT: I would like to mention it the smoke doesn’t appear immediately after driving , I have to drive for like maybe 5 mins or so before it shows up(doesn’t happen when car is left on and chilling in neutral) . I want to drive the car more to rule out residue on the exhaust but scared to hurt the engine |
#2 |
Drives: Crapcan
If you are burning oil it will appear blue through the exhaust. Oil flashing off on a hot part is usually white. You either have an oil leak, or some greasy mechanic didn't do a good job degreasing parts after touching them with his grubby hands. It doesn't appear for 5 minutes because it has to get hot enough.
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | alphasaur (01-26-2023), x808drifter (01-26-2023) |
#3 | |
Tjae
Crossing fingers it’s just left over residue but expecting worse case scenario to not get disappointed . |
#4 |
Drives: Crapcan
Doesn't really tell us anything unless we can see where it is coming from. Pull the engine skid off and look under the car with a flashlight. It's either residue burning off the exhaust, or an oil leak. Could be timing cover, valve covers, AVCS solenoid, vacuum pump block off plate on the back side of the passenger head. Or take it to the shop that did the work and have them inspect it.
#5 |
#6 |
LMGTFY
Drives: 13 FRS, 91 Miata
^ That
Or stop using a format from the early 90's. XD |
#7 |
Tjae
#8 |
LMGTFY
| The Following User Says Thank You to x808drifter For This Useful Post: | soundman98 (01-27-2023) |
#9 |
Tjae
Update: It's still the camplate, now time to d some research on best way on stopping that annoying leak
#10 |
Drives: Crapcan
Properly seal it and put it back on. They make aftermarket cam plates that have orings, though I think it is recommended that you still run some FIPG on it.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | x808drifter (01-29-2023) |
#11 |
Tjae
Thanks , shop has it and they even bought Subaru sealant and followed dealers instructions but said they still have a leak. So I'm looking to getting a aftermarket. I was going to get Raceseng but I see those are now discontinued so going with something else I suppose
#12 | |
Rust bucket enthusiast
He's got one for sale
#13 | |
Tjae
| The Following User Says Thank You to Tjaen6 For This Useful Post: | DarkPira7e (01-27-2023) |
#14 |
Did a new cam plate fix this?
| White Smoke from engine bay | checkraise36 | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 09-04-2024 09:15 AM |
| White smoke from engine bay | ffsrhys | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 09-04-2024 09:14 AM |
| Smoke from engine bay due to oil leak? | boksajak | Issues | Warranty | Recalls / TSB | 9 | 11-26-2020 03:26 PM |
| Is it OK to raise engine a little bit on passenger side using washers? | darkbluemn | Engine, Exhaust, Transmission | 43 | 01-10-2018 09:39 PM |
| White smoke in Engine bay | Pinoywhiz | Engine, Exhaust, Transmission | 7 | 04-07-2014 07:10 PM |
