Old 01-25-2023, 12:44 PM   #1
Tjaen6
Tjae
Tjaen6's Avatar
Drives: 2014 Scion FRS Black
Unhappy Smoke from engine bay, passenger side
Hello I have a 2014 Scion FRS with with an engine swap .
After completing engine swap and getting everything checked at a shop the car seemed ready to go . After driving it home I smelt a burning smell and there was smoke come up from passenger side of engine bay, I suspected the cam plate may still have a minor leak . However the smoke is WHITE and I read blue means oil. The smoke I hope seems to be coming from something burning off the exhaust manifold
Yesterday 1/25/23 I drove the car again and same thing happened , so when I got home I turned on car and left it idle as I walked dog in the yard nearby to see if the smoke would come. It doesn’t show up when idle at least not within 20 mins, the smoke only appear when I drive the car at moderate speeds like 40-50 mph. My assumption was the cam plate may still be leaking but when I rub a napkin down there I see no oil (it was leaking past but shop said they fixed it) . My next guess is maybe there is residue left over on exhaust someway somehow and it’s burning off or worse case scenario It may be coming from something else like the timing cover even tho I don’t feel it.
Taking it back to shop tomorrow and they said they will try to see what’s causing it.
TL;DR: I just want to drive car, it’s been out of commission for around 8 months and I finally put the money down to get everything installed and everything seems fine until I drive and I see the white smoke and burning smell from engine bay in the left side.
EDIT: I would like to mention it the smoke doesn’t appear immediately after driving , I have to drive for like maybe 5 mins or so before it shows up(doesn’t happen when car is left on and chilling in neutral) . I want to drive the car more to rule out residue on the exhaust but scared to hurt the engine
Tjaen6 is offline   Reply With Quote
Old 01-25-2023, 01:02 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
If you are burning oil it will appear blue through the exhaust. Oil flashing off on a hot part is usually white. You either have an oil leak, or some greasy mechanic didn't do a good job degreasing parts after touching them with his grubby hands. It doesn't appear for 5 minutes because it has to get hot enough.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
alphasaur (01-26-2023), x808drifter (01-26-2023)
Old 01-25-2023, 02:16 PM   #3
Tjaen6
Tjae
Tjaen6's Avatar
I would upload a 6 second video I have of the smoke coming from engine bay but says invalid format because it’s a .MOV.
Crossing fingers it’s just left over residue but expecting worse case scenario to not get disappointed .
Old 01-25-2023, 02:57 PM   #4
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Doesn't really tell us anything unless we can see where it is coming from. Pull the engine skid off and look under the car with a flashlight. It's either residue burning off the exhaust, or an oil leak. Could be timing cover, valve covers, AVCS solenoid, vacuum pump block off plate on the back side of the passenger head. Or take it to the shop that did the work and have them inspect it.
Old 01-25-2023, 06:45 PM   #5
daniloneil8
Youtube
daniloneil8 is offline   Reply With Quote
Old 01-26-2023, 06:11 AM   #6
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
^ That
Or stop using a format from the early 90's.
XD
Old 01-26-2023, 03:05 PM   #7
Tjaen6
Tjae
Tjaen6's Avatar
Originally Posted by x808drifter View Post
^ That
XD
I don’t decide how iPhones are coded .
Car in shop, will update
Old 01-27-2023, 06:52 AM   #8
x808drifter
LMGTFY
Should have put /s.
Still unless you have an old iPhone like I have. 9 and up allows you to change that to "More Compatible" in settings that changes it to MP4.
5 secs of googling.
The Following User Says Thank You to x808drifter For This Useful Post:
soundman98 (01-27-2023)
Old 01-27-2023, 12:11 PM   #9
Tjaen6
Tjae
Tjaen6's Avatar
Update: It's still the camplate, now time to d some research on best way on stopping that annoying leak
Old 01-27-2023, 12:28 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Properly seal it and put it back on. They make aftermarket cam plates that have orings, though I think it is recommended that you still run some FIPG on it.
x808drifter (01-29-2023)
Old 01-27-2023, 12:40 PM   #11
Tjaen6
Tjae
Tjaen6's Avatar
Thanks , shop has it and they even bought Subaru sealant and followed dealers instructions but said they still have a leak. So I'm looking to getting a aftermarket. I was going to get Raceseng but I see those are now discontinued so going with something else I suppose
Old 01-27-2023, 12:44 PM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
https://www.ft86club.com/forums/showthread.php?t=152310
He's got one for sale
Old 01-27-2023, 12:51 PM   #13
Tjaen6
Tjae
Tjaen6's Avatar
Originally Posted by DarkPira7e View Post
Lol, thanks. I am actually currently already PMING Him
The Following User Says Thank You to Tjaen6 For This Useful Post:
DarkPira7e (01-27-2023)
Old 09-04-2024, 09:16 AM   #14
daniloneil8
Did a new cam plate fix this?
White Smoke from engine bay checkraise36 Scion FR-S / Toyota 86 GT86 General Forum 4 09-04-2024 09:15 AM
White smoke from engine bay ffsrhys Scion FR-S / Toyota 86 GT86 General Forum 20 09-04-2024 09:14 AM
Smoke from engine bay due to oil leak? boksajak Issues | Warranty | Recalls / TSB 9 11-26-2020 03:26 PM
Is it OK to raise engine a little bit on passenger side using washers? darkbluemn Engine, Exhaust, Transmission 43 01-10-2018 09:39 PM
White smoke in Engine bay Pinoywhiz Engine, Exhaust, Transmission 7 04-07-2014 07:10 PM
