Drives: 17 BRZ w/PP & 08 STI
Pedders offset camber/caster strut mount - sheared bolt
Just an FYI to those of you using pedders top mounts.
I had one of the 3 nuts back off to the point that there was enough play to create a feint clunk over a year ago, so I've been re-torqing the nuts to 17 ft/lb on oil changes just for piece of mind. 2nd oil change retourqing - and one of the bolts sheared. I love them otherwise, so I ordered another but figured I would post up to see if others have heard of this? |
#2 |
Are you using the oem nuts? Unfortunate to hear, but you may have just gotten a bad batch.
I’m on my 2nd set and all is well. |
#3 |
#4 |
#5 |
Little dab of Loctite blue will fix that right up.
| The Following 3 Users Say Thank You to Ultramaroon For This Useful Post: |
#6 |
Drives: 2016 BRZ
| The Following 2 Users Say Thank You to Joon525 For This Useful Post: | TwinFTW (01-30-2023), Ultramaroon (01-13-2023) |
| >>SOLD<< RACESENG Adjustable FRONT CAMBER + CASTER Strut Mount Plates | Lightened | Brakes, Suspension, Chassis | 7 | 09-16-2019 04:09 PM |
| Pedders offset front strut mount? Any knowledge? | 7 skulls | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 03-20-2019 04:20 PM |
| Pedders Top Hat w/ Camber & Caster Offset - Anyone with experience? | Jamestl | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 11-16-2018 05:35 PM |
| Those Who Have Cusco Strut Bar, Which Camber Top Mount Do You Run? | Figo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-03-2013 05:01 PM |
