#57 | |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
#58 | |
#59 |
Drives: Crapcan
It honestly sounds like it could be a missalgined clutch disc too. I bought the OS Giken tool just to avoid some of the clutch install issues that can be causes by the plastic installation tool.
| The Following 5 Users Say Thank You to NoHaveMSG For This Useful Post: | CSG Mike (12-14-2022), Jdmjunkie (12-14-2022), soundman98 (12-14-2022), Wally86 (12-22-2022), x808drifter (12-17-2022) |
#60 |
Please keep elaborating as I don't follow how this won't self correct.
#61 |
Drives: 1999 Miata
This could also have been clutch chatter from oil being left on the pressure plate or flywheel during installation. I have also seen cases where someone lubes up the transmission input shaft a little too much and flings grease onto the clutch.
The oil on the contact surfaces causes slip/grip and hot spots and can lead to chatter.
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
#62 | |
Drives: 2013 frs base
If the clutch disc is successfully "aligned" to allow installation of the transmission, what other "alignment" is relevant? I do not feel that I can move forward into the new year without understanding this concept. |
| The Following User Says Thank You to blsfrs For This Useful Post: | Decep (12-30-2022) |
#63 | |
Drives: Crapcan
| The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post: |
#64 | |
#65 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | blsfrs (12-31-2022) |
#66 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | blsfrs (12-31-2022) |
#67 | |
#68 | |
Drives: Crapcan
#69 |
Oh, it's nice. The plastic ones suck. I'm thinking input shaft from a junk transmission.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | x808drifter (01-02-2023) |
#70 | |
I would say that 98% of the time, the plastic tool will work just fine, if you are careful. |
| The Following 2 Users Say Thank You to blsfrs For This Useful Post: | NoHaveMSG (12-31-2022), Ultramaroon (12-31-2022) |
| Bucking on throttle application? | Mr_Eyo | Software Tuning | 57 | 11-21-2018 03:45 AM |
| E85 OFT tune Bucking/surging | Vmax911 | Software Tuning | 5 | 07-30-2017 04:27 AM |
| Horrible bucking and shutter after clutch install | Scikotic | Engine, Exhaust, Transmission | 32 | 07-12-2016 09:10 PM |
| 2-3K RPM hesitation/bucking - logged | 86fun | Software Tuning | 5 | 01-29-2016 09:58 AM |
| loss of power/ bucking in rain | fasteddy | Issues | Warranty | Recalls / TSB | 30 | 10-20-2015 03:08 AM |
