Old 12-23-2022, 01:27 AM   #29
Personally, I've never had trouble massaging a disc into place with those plastic tools. It just takes some feel and patience.
A picture of ol @Ultramaroon "massaging" something into place with "feel and patience" -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
bcj (12-23-2022), Spuds (12-23-2022), Ultramaroon (12-23-2022), x808drifter (12-23-2022)
Old 12-23-2022, 01:31 AM   #30
Right tool for the job
humfrz (12-23-2022), x808drifter (12-23-2022)
Old 12-23-2022, 01:50 PM   #31
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Who?
Old 12-23-2022, 02:19 PM   #32
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I'm not suggesting "do it this way." I'm just sharing, FWIW. If a verus fork dropped into my lap, here's how I'd play it.
There are two critical flaws in the factory design.
1. The main pivot begins to creak - a violent event given the forces involved - when the socket wears into the flat face of the ball deeply enough. No amount of lube prevents that.
2. The center bushing of the TOB and that quill are a shit combination. When the fretting gets deep enough, they bind.
If the verus ball is fully spherical, I'd modify the verus fork to fit the tsk bearing.
Otherwise, I'd modify the old fork the same way I did the last time I had mine apart. I used a dremel to grind out enough of the center of the socket so none of it ever comes into contact with the flat part of the ball. It has cured the creak.
Modifying the Verus fork to fit doesn't seem like an option. At least not one I'm willing to try.
I don't understand the flat ball problem. The Verus pivot actually has a bit more flat space on top, but that could be because the OEM bearing has been worn down a bit?
Really, it's coming down to if I want to do the extra work for a slightly tougher clutch and order that and a TOB, or just install what I have with the stock fork while my dad and/or brothers are here to help lol. Stock fork looks good, but there was a lot of clutch dust in the bell housing...
Also: "Build Thread"
The Following 3 Users Say Thank You to Spuds For This Useful Post:
soundman98 (12-23-2022), Ultramaroon (12-23-2022), x808drifter (12-24-2022)
Old 12-28-2022, 03:41 PM   #33
Spuds
The Dictater
Spuds's Avatar
New question, what grease should I use to get the shifter bracket pins back into place? Tech manual from @Ultramaroon sig () indicates to use MP grease. I've got some Mobil 1Synthetic Grease, but I read that might damage the rubber bushing over time.
Old 12-28-2022, 06:49 PM   #34
I switched to this stuff the last time I dropped the trans to fix the creak. It has held up well coming up on three years. The factory stuff and equivalents are junk. They separate and end up as a sticky, hard mess.
I pulled the ball off of my original to take pics but it, and my original fork aren't worn nearly enough to visibly illustrate the wear pattern.
edit: Oops... I should read more carefully before replying. Sorry about that. I have an ancient little tub of NAPA-branded axle grease for the MP stuff.
Spuds (12-29-2022)
Clicking sound when Pressing Clutch Pedal Archetyp3 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 01-03-2020 12:57 PM
Whining noise when pressing clutch? cupcake917 Issues | Warranty | Recalls / TSB 14 03-12-2019 02:49 PM
RPM goes up to 1.5k when pressing the clutch while slowing down pcuerpo Issues | Warranty | Recalls / TSB 13 02-28-2018 02:37 AM
Is it bad to have my ankle fully extended forward when pressing the clutch? cat94 Scion FR-S / Toyota 86 GT86 General Forum 70 11-24-2016 05:10 PM
Upgraded Clutch now seems like TOB is pressing on pressure plate when not depressed. Rybot Issues | Warranty | Recalls / TSB 35 03-06-2016 09:23 PM
