Drives: Whiteout FRS
Coilover Clunk (Brand new)
Ok so I just installed my coilovers (not going to say which brand for fear this may just be a bad one and I dont want to slander their brand). Anyways I just installed them and I got this wicked clunking noise in the rear right mount. They are pillow ball rears and I tried using an impact gun on the upper shaft bolt but it didnt seem to change anything. Ive fully removed the coilover and inspected it for play and leaks but it seems 100% fine. Could this be something other than the pillowball mount making this noise?
[ame="http://www.youtube.com/watch?v=hf0OMGdrMCs&feature=plcp"]Gt86 coilover clunk - YouTube[/ame] |
#2 |
Drives: 2013 asphalt fr-s
I had this noise on the BC coilovers I had on my old car. It always did that, I hated it do much.
#3 |
Drives: 2013 BRZ Limited
I'm going to take a shot in the dark and guess you paid less than 1000$ dollars for said coil overs
#4 |
It only seems to be coming from one side though, so obviously somethings wrong with it
#5 |
And list on them is over 2k
#6 |
Drives: Toyota 86
Lol at the immediate assumption that they're under 1k
| The Following User Says Thank You to blags For This Useful Post: | dabocx (08-02-2012) |
#7 |
White86: Contact the manufacturer. If it's new, they should be able to offer you a replacement pillow bearing. Should do the trick.
Epson1: Wouldn't be to quick to jump to conclusions. We've had an Evo X in here with Ohlins DFV's with both front and rear pillow ball bearings that clunked louder then that. It's even a common issue with Evo X front OEM upper mounts which are spherical bearing with rubber bushing around it. Pillow ball bearings sometimes go bad. They are a wear and tear item. The tolerances on the bearings are so tight then even a .1mm wear can lead to a loud clunk in a car. |
| The Following 2 Users Say Thank You to Touge Factory For This Useful Post: | hmong337 (02-25-2015), TylerLieberman (04-09-2014) |
#8 |
Thanks, ya the manufacturer already said they would replace it. I'm gonna disassemble the top mount tonight and see what's up. Yea they're expensive coils but that doesn't really mean anything. I realize not everything can be perfect and shit happens and slips through the cracks. That's why this is a throwaway account because I want to give the manufacturer the benefit of the doubt
#9 |
Kurenai Samurai
Drives: Red and manual
they warned us about upsetting the balance of this vehicle...jkjk
| The Following User Says Thank You to driftartist For This Useful Post: | jumbaco (04-16-2013) |
#10 | |
Drives: Pegasus White 86GTS
Pegasus White 6MT got it. :happy0180:
#11 |
Drives: 2014 Widebody Cosworth FR-S
Do these have a helper spring on them? If not, did you check to make sure the pre-load was good on that one damper? It sounds like an upper mount to me, but trying to think of what else it may be.
Thanks, Rick |
#12 |
Drives: Past S13 S14 350Z, Future FRS
Def bad pillowball, replace and should do the trick goodluck.
#13 |
Did you remove the lower sway bar end link bolt from the control arm?
#14 | |
Thats because they are crap. I've installed a few of those and you need to put a ton of preload in the spring itself on the body. But that makes it ride like garbage. |
| Clunk when going into first gear? | huma | BRZ First-Gen (2012+) — General Topics | 22 | 07-24-2014 05:49 PM |
| DG-5 Coilover | harajukukei | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 06-27-2014 03:42 PM |
| Parking brake clunk | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 06-28-2012 12:10 AM |
| Parking/Emergency Brake - "Clunk" | EsoBOFH | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-24-2012 11:43 AM |
| Thud/Clunk when shifting. | erom | Engine, Exhaust, Transmission | 10 | 06-17-2012 07:08 PM |
