Old 12-07-2022, 11:56 AM   #15
SpeBud07
Drives: 2013 FRS
Originally Posted by whataboutbob View Post
You didn't mention what front pipe you had on the car, but ensuring that you at least have the stock catted front pipe typically helps with rasp/noise. An aftermarket catted front pipe may help more than the stock one.
It's got a stock front pipe. From my experience, even the catted ones can make it worse? Is that not always the case?
SpeBud07 is offline   Reply With Quote
The Following User Says Thank You to SpeBud07 For This Useful Post:
whataboutbob (12-07-2022)
Old 12-07-2022, 12:05 PM   #16
KillerBMotorsport
KillerBMotorsport's Avatar
Originally Posted by SpeBud07 View Post
I was wondering about that, trying a resonator and seeing what difference that makes. Of course doing that would potentially kill resale of it, but it may be worth the experiment.
Depending on the severity of the drone a resonator may not solve it. We had a car with bad drone and tried four different resonators and it would move the drone around on the rev range some (up or down a few hundred RPMs) or change the tone some, but it would still be there. That car we changed to a coated carbon steel exhaust, and it was whisper quiet in the car, but still balls out on the outside. Carbon Steel and Stainless have extremely different resonance properties.
A few other cars have had moderate drone and we used a Helmholtz tube on them. It completely cancelled the drone.
KillerBMotorsport is offline   Reply With Quote
The Following 2 Users Say Thank You to KillerBMotorsport For This Useful Post:
RToyo86 (12-07-2022), SpeBud07 (12-07-2022)
Old 12-07-2022, 12:07 PM   #17
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I personally didn't want to bother with the experiment but it's certainly cheaper than buying another catback.
CSG touring is the only CB I will buy new going forward. Made for catless setups.
Generally the stock FP is going to be the most tame. I've got a 2.5" Catted and bottle resonated unit now that drones worse than OEM with CBs I tried. Lachute makes a ultra quiet resonated version I wish I knew about. I probably would have purchased that instead.
https://lachuteperformance.com/en/co...39637417099330
Old 12-07-2022, 01:08 PM   #18
SpeBud07
Drives: 2013 FRS
I may try this one before I change the CB. I was planning to change out the front pipe anyway at some point, so perhaps this will influence some of the rasp/volume I'm getting on the TRD?
Could be chasing good money with bad though.
** EDIT ** I exchanged email with Lachute and they won't sell one to the US because we are nutty over cats. Maybe I can find a Canadian friend to buy one and send it to me.
Old 12-07-2022, 10:22 PM   #19
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
TRD exhaust owner here...
I replaced the original resonator with a Vibrant Ultra Quiet unit and it got rid of 95% of the drone, so I'd highly recommend doing this for drone reduction (resonators don't have much effect on volume). Interestingly, the resonator on the Lachute front pipe looks identical to a Vibrant Ultra Quiet resonator...
Based on what I've read over the years, I don't recall any aftermarket front pipe that helps reduce volume over the OEM front pipe since they typically have larger piping and higher-flow cat. The closest exception I've seen is the Fujitsubo dual-resonated (but catless) front pipe, which was extensively tested to be identical to the OEM front pipe in dB readings.
If you want to cut down volume, it's either different cat-back or maybe replace the TRD muffler with a larger one and cut/weld the TRD tips onto it. Perhaps this Vibrant muffler could help:
https://vibrantperformance.com/trans...ufflers-v1248/
Old 12-07-2022, 11:47 PM   #20
whataboutbob
AutoX-10/10ths every run
From what I've seen on here they can, but some of the double resonated front pipes may actually help.
Build thread:Here
Old 12-08-2022, 01:07 AM   #21
jflogerzi
jflogerzi's Avatar
Listen to what others have said. CSG Touring only way to go at a reasonable price. If you still have stock Mid Pipe, this exhaust will also work(use to run it when my car was street driven. For FP's go with JDL OP/FP Combo with Dual Resonators
Fujitsubo Authorize S Axle Back Exhaust
2013 Series 10 FRS #553
Old 12-08-2022, 01:11 AM   #22
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Nameless catted and resonated FP also works well.
PSA- Don't race on streets. Could Stance have created this crash? guybo Off-Topic Lounge [WARNING: NO POLITICS] 52 11-27-2016 11:24 PM
Does snow & ice mess up car paint? Jfheisenberg Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 02-05-2015 08:37 AM
not all USB keys created equally? 7thgear Electronics | Audio | NAV | Infotainment 15 06-28-2013 08:33 PM
My FR-S is a mess SocalBurt Issues | Warranty | Recalls / TSB 17 11-21-2012 04:23 PM
