#29 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
There are no finishing/machine marks, zero, it was 100% cast. You can now see wear on the ball pivots and where the fork touches the TOB. And again, mine exhibited the problem from day one.
#30 |
Do you still have the fork? I'd like to examine it if you are game.
#31 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (12-06-2022) |
#32 |
Forged, okay I see it now. How do I share pics? It does have two holes and some pockets milled at fork end for clip retention. The pivot clip is milled open. I do see what looks like a mold part line, or rather a forge line like a high pressure stamping.
The interesting bit is the wear, the pivot pocket has significant wear you can feel with your fingernail like a button from the drilled open top of the pivot ball. I'd guess 10-20 thousandths of an inch. |
#33 |
Drives: Crapcan
Like this ? This is a used fork I picked up.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | jeepmor (12-09-2022) |
#34 |
Drives: Crapcan
For shits n giggles I ran back and threw it in my hardness tester. Granted I didn't sand in a smooth spot and level it but it's pretty hard. I would say it's in the range of 34-38 hrc. A decent high carbon knife or a truck leaf spring is about 42 hrc for reference. I would shoot Verus a message. They are pretty responsive and care about the product they put out.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Wally86 (12-07-2022) |
#35 |
are the fork tines symmetrical about the center plane?
#36 |
Drives: Crapcan
In my 4 handed attempt at taking a picture of it, it's close but it looks like it's off a smidge. Hard to tell without another set of hands. Could have it off the peak a bit on one side. I didn't check the lengths.
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | Ultramaroon (12-07-2022) |
#37 |
Famous Potatoes
Drives: '15 ultramarine
Use the right measure.
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | NoHaveMSG (12-06-2022), Ultramaroon (12-06-2022) |
#38 |
It's ok. I would set up a jig with a camera and plug that into inkscape.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | NoHaveMSG (12-07-2022) |
#39 |
#40 |
Drives: Crapcan
Would be nice if I could just scan it and port it into solid works. Even nicer if I could scan the stock one too and have SW merge the two and match points.....but I sold my scanner.
#41 | |
![]() I killed my scanner by leaving it on a shelf for too long.
#42 |
Drives: Crapcan
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | jeepmor (12-09-2022), Ultramaroon (12-07-2022) |
| Bucking on throttle application? | Mr_Eyo | Software Tuning | 57 | 11-21-2018 03:45 AM |
| E85 OFT tune Bucking/surging | Vmax911 | Software Tuning | 5 | 07-30-2017 04:27 AM |
| Horrible bucking and shutter after clutch install | Scikotic | Engine, Exhaust, Transmission | 32 | 07-12-2016 09:10 PM |
| 2-3K RPM hesitation/bucking - logged | 86fun | Software Tuning | 5 | 01-29-2016 09:58 AM |
| loss of power/ bucking in rain | fasteddy | Issues | Warranty | Recalls / TSB | 30 | 10-20-2015 03:08 AM |
