Old 08-26-2022, 06:49 AM   #1
Ace23_BRZ
Ace23_BRZ's Avatar
Drives: 2013 Subaru BRZ
Post Question about Cusco Vs SPL
Hey everyone,
I am looking for some insightful advice as to what components are better if any.
I typically like to stick it out with 1 manufacturer and would like some helpful advice as to what you folks suggest, Cusco, SPL, or any other brand for complete suspension upgrade(s).
I really like to look of the SPL components because they tend to go with my entire car's theme, however, I do want reputable parts that are worth the money.
I will drag this car once n a while, lol, once I learn how to get sideways, possibly drift it as well.
Either way, I have an AirLift suspension, will be running a full widebody kit, and around 700+ HP max...if that helps?
I look forward to hearing from you folks and appreciate the advice in advance.
V/R,
Ace
Ace23_BRZ is offline   Reply With Quote
Old 08-26-2022, 09:28 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
SPL and Cusco are both proven, either will be fine. Racer-x, Verus, Voodoo13, White line, PartsShopMax, Whiteline, it's all good stuff. Avoid lowest dollar parts and Google with the following strategy - BRAND PART FT86CLUB
Example:. CUSCO LCA FT86CLUB
You'll find this https://www.ft86club.com/forums/showthread.php?t=38160
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Ace23_BRZ (08-26-2022), Kiske (08-27-2022)
Old 08-26-2022, 08:39 PM   #3
Ace23_BRZ
Ace23_BRZ's Avatar
Koo, thanks brother
Old 08-26-2022, 11:04 PM   #4
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
The Cusco parts are made from multiple pieces of aluminum and welded together. The SPL units are milled from one solid piece of aluminum. The Cusco parts are more affordable than the SPL versions. SPL is an American company if that matters to you. They both probably perform functionally equivalent to each other.
SPL does not make rear upper control arms, so if you want to replace all of the suspension arms you won't be able to have all SPL. I recently contacted SPL to ask about them making RUCAs for the 86 and they said it is something they are looking into. Who knows how long the development could take, though.
You should also consider Racer X. They make some nice control arms.
Mike_ZN6 is offline   Reply With Quote
The Following User Says Thank You to Mike_ZN6 For This Useful Post:
Ace23_BRZ (08-27-2022)
Old 08-27-2022, 03:07 AM   #5
Ace23_BRZ
Ace23_BRZ's Avatar
Yeah, that is another consideration as well. Cusco, unlike SPL has a multitude of suspension parts, whereas, SPL is fairly limited.
I appreciate the info folks, and yeah, I'm pretty sure I'll just look into Cusco products.
V/R,
Ace
Old 08-27-2022, 03:13 AM   #6
Ace23_BRZ
Ace23_BRZ's Avatar
I think I'm good with the info...
LoL, how do I delete this thread??
Old 08-27-2022, 05:09 AM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Does google not exist in your world?
Old 08-27-2022, 07:16 AM   #8
new2subaru
Weight Weenie
Drives: 15 FR-S
Don't, leave it here for other people. That's what makes forums better.
The Following User Says Thank You to new2subaru For This Useful Post:
ZDan (08-28-2022)
Old 08-27-2022, 09:04 AM   #9
Mike_ZN6
Mike_ZN6's Avatar
Don't delete the thread, lol. The point of the forum is so other people can come read this post in the future.
For what it's worth - my dream setup is all SPL suspension components.
Ace23_BRZ (08-29-2022)
Old 08-27-2022, 09:06 AM   #10
Mike_ZN6
Mike_ZN6's Avatar
V/R,
Ace
SPL makes literally every suspension control arm for the 86 except the RUCAs.
Old 08-29-2022, 02:43 AM   #11
Ace23_BRZ
Ace23_BRZ's Avatar
Haha, ahhh, gotcha.
Yeah, I just didn't want to keep posting more and more threads...but what you're saying makes sense.
Thanks!
V/R,
Ace
cusco strut bar with master cylinder brace question DarkSideFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-18-2018 10:23 PM
Cusco Differential brace install question (SOLVED) Sportsguy83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 07-09-2016 05:14 PM
Cusco catch can mounting point question dar3d3vil Engine, Exhaust, Transmission 4 05-24-2015 04:41 PM
Help, cusco lca question BadLuckZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 06-01-2013 06:42 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 03:11 PM
