Old 06-01-2013, 04:46 AM   #1
BadLuckZN6
BadLuckZN6's Avatar
Drives: GT86
Help, cusco lca question
I installed tein coilovers a am now in the process of installing the cusco lower control arms. When fitting the arm, the end link from the sway bar seems to be bending. Do I need adjustable links when running lca? Or should I be adjusting something
BadLuckZN6 is offline   Reply With Quote
Old 06-01-2013, 05:42 PM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
you mean the bolt is pivoting? it's meant to be able to.
I doubt you are bending the actual rod.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin JM Auto Racing Brakes, Suspension, Chassis 271 03-22-2014 12:17 PM
Question for the guys with the cusco spin knob "drift" knob Juurian Cosmetic Modification (Interior/Exterior/Lighting) 5 03-13-2013 08:51 PM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
Cusco Rear Diff Covers!!! Cusco LSD Units! vividracing Transmission and Driveline 0 06-18-2012 03:24 PM
