BRZ Second-Gen (2022+) -- General Topics General topics for the second-gen BRZ |
05-26-2022, 06:25 PM | #1 |
Drives: 2022 MT Neptune GR86 Prem.
Oil changes/Fumoto valve...
I'm assuming I wasn't the only one who was annoyed to find out the simple/easy small hole in the underbody panel for oil changes (which easily accommodated a Fumoto valve) in Gen 1 has been changed to a 3 bolt removable panel in Gen 2. Not sure if the Fumoto valve fits under this panel, but regardless, having to remove the panel in the first place sort of defeats the purpose of the Fumoto valve, namely not having to use any tools at all for an oil change (unless you screw your oil filter on too tight).
In any event, was curious if anyone has tackled this yet. Given it's size, I don't really want to just leave the panel off - it's a lot bigger hole than what was on Gen 1. Was thinking of just cutting the smallest possible hole in the panel using an angle grinder. Thoughts on this? Anyone done it already and have a picture? Want to make the hole as small as possible while still giving relatively easy access to the valve. Any other ideas? |
05-26-2022, 06:28 PM | #2 |
TRACKBREAD
The fumoto valve fits, but the clearance to the panel isn’t enough to make me feel comfortable with it. Unlike my 2013 I decided to deal with it and go with the drain plug for now.
05-26-2022, 06:47 PM | #3 |
Drives: '23 BRZ Limited
Just get an oil extractor and you don't even have to lift the car up.
Then again, I take advantage of my flex schedule and just the car to the shop and work from there over WiFi while they handle it.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Jdmjunkie (05-26-2022) |
05-26-2022, 07:13 PM | #4 | |
And I believe we've had this discussion, but there are multiple good reasons to change your own oil (cost, convenience). But the biggest, by far, is to make sure you get the oil and filter that you want and know is correct and that it was actually done, correctly. Not to mention, any chance you can get to keep someone else from driving your car without you in it is worth it IMHO. |
The Following 2 Users Say Thank You to CincyJohn For This Useful Post: | CaptainFenderbaum (05-27-2022), Wally86 (05-27-2022) |
05-26-2022, 07:16 PM | #5 | |
I still think cutting a small hole in the panel is the answer... |
05-26-2022, 07:27 PM | #6 |
Drives: 22 BRZ limited
I use the fumoto and use my M18 surge to remove and reinstall the bolts on the lowest setting. I attach the fitting with the hose, drain and walk away for a bit (after fiddling with the filter change).
05-26-2022, 07:30 PM | #7 |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
The underbody panel change was to discourage the use of the valve because 1) some people will take their car to the dealer for an oil change, and 2) to address the too often occurring problem where us gen1 idiots bottom out our cars going over speed bumps at 40 mph, drop all the oil, and drive another 150 miles until the engine seizes up.
Either that or it's a conspiracy to piss off owners of both generation. |
05-26-2022, 08:43 PM | #8 | |
I had a scare once where somebody had left a mini-manhole cover for a water valve or something on the road at night and I drove over it at full speed. Very scary bang and a nice gash in the panel. Thankfully not near the valve. |
05-26-2022, 08:46 PM | #9 |
ProCrastinationConsultant
to this day, i genuinely don't understand why the most common service to perform to an ICE vehicle requires wrenches, and getting covered in oil.
The Following 2 Users Say Thank You to soundman98 For This Useful Post: | STLBRZ66 (05-22-2023), Yoshoobaroo (05-26-2022) |
05-26-2022, 09:34 PM | #10 | |
I guess maybe that's a concern for people going to Jiffy Lube, but I take my cars to the guy who at any time has Ferrari's, Saleen's, Lambo's, or his own Viper in the bay. What world do you live in where cars are driven after an oil change by the techs, or are you just making things up? Or do you consider the 400 ft driving the car from the back to the front of the shop as somehow damaging? As for cost/convenience? I literally spent $10 more to have an indy pro change the oil in my 135 vs doing it myself. I get to "work from the shop" for the morning and not get dirty, or spend an hour in the garage on a saturday? That $10 more is totally worth it.
05-27-2022, 12:08 AM | #11 |
Drives: '22 BRZ
I went the the non-nippled fumoto to maximize clearance. It fits fine, but certainly not a ton of extra clearance. Easiest oil change ever.
The Following User Says Thank You to eyeballs For This Useful Post: | Wally86 (05-27-2022) |
05-27-2022, 12:10 AM | #12 |
Anti-Social Media
Drives: 24 GR86 Premium MT is on the way!
Are dealership techs going to have a cow over my Fumoto valve? I installed the short nipple version. It fits fine under the panel hatch and points in the preferred direction.
05-27-2022, 12:51 AM | #13 |
couldn't tell you. i'm too paranoid to ever allow anyone to work on my vehicles that i don't have their personal number/home address.
i went to lincoln tech. cars went into those bays for a tire change, and left with the steering wheel crooked and a broken tail light...
The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
05-27-2022, 08:55 AM | #14 | |
As for the extractor, it's not about the amount of oil. It's about sucking oil through a tube that engineers didn't design oil to be sucked out of. If nothing else, I don't like the idea of coating the entire inside of the oil pan/sump and everything else with the used contaminated oil when I can drain it through the bottom as it was designed to leaving whatever particles might be in the oil at the bottom of the pan. Also, having being an engineer, I am always leery of placing any kind of pressure or vacuum on a system that wasn't designed for that. And yes, I don't like people I don't know and trust driving my car at anytime for any reason (one of many, many reasons I don't like/use valets - ever). |
Similar Threads | ||||
Fumoto oil drain valve | amelo | BRZ Second-Gen (2022+) -- General Topics | 13 | 02-11-2022 09:54 PM |
FS: Fumoto Drain Valve | turbos86 | Engine, Exhaust, Bolt-Ons | 2 | 03-15-2017 06:41 PM |
FS: Fumoto Valve | jvenetto | Engine, Exhaust, Bolt-Ons | 6 | 10-01-2015 07:16 AM |
Fumoto valve in the winter? | Muskokan | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 02-25-2014 12:06 PM |
Fumoto valve for transmission? | SurfAndSand | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 2 | 09-15-2013 11:01 PM |
