Drives: Toyota 86
Stumped: Oil pressure switch port
This one has me a bit confused. I'm trying to re-purpose the oil pressure port on the engine to add an aftermarket sensor by using a splitter-T. For whatever reason the fitting will not screw into the engine. I have purchased two separate fittings and neither fits. But both of the sensors (the OEM and aftermarket) fit in the engine port and into the splitters. I can even fit the splitters into one another, but in the end neither will screw into the engine by more than half turn. I don't want to strip the threads so I'm hesitant on adding significant force.
Anybody got any ideas? |
#2 |
Drives: Crapcan
Is that adaptor pipe thread, or BPST thread?
#3 |
Drives: Toyota 86
#4 |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | TheBoss77 (05-20-2022) |
#5 | |
Drives: Toyota 86
Gotcha! Thank you. I'll see if I can find a BPST to NPT splitter.
#6 | |
Drives: Crapcan
#7 | |
Drives: Toyota 86
I'm just glad that there's a reasonable explanation for the issue and it's not me going crazy or senile. The temp sensor is the one with the longer probe, the pressure sensors are short, definitely no fitment issues there.
#8 |
Drives: 2015 FR-S
https://www.amazon.com/gp/product/B0...9ROA0I31&psc=1
Just use this adapter, on the end you put the original oil dummy light, on the sides you put your oil pressure sensor |
| The Following User Says Thank You to FrickingReallySlow For This Useful Post: | TheBoss77 (05-20-2022) |
#9 | |
Drives: Toyota 86
Thanks, but I ended up buying an adapter with BSPT male, BSPT female and NPT female. That way the stock pressure sensor will fit correctly. It's coming from China so it's going to be a while. EDIT: Disregard the above, realized that this thing also has BSPT female. |
#10 |
Drives: FRS Hot Lava
There is an oil port on top of the engine, closed by a 10mm Hex if I am not wrong.
Looks like safer than havinf an string of connector/splitter. At least is what I did. |
| The Following User Says Thank You to fminicooper For This Useful Post: | Jdmjunkie (05-20-2022) |
#11 | |
Drives: Crapcan
https://www.rallysportdirect.com/par...waApocEALw_wcB
#12 | |
Drives: Toyota 86
Thanks, but I'm already running oil temp sensor in the galley. Can't use the Tee there because the oil temp readings are way off from what OBD is reporting. |
#13 |
Be careful adding a lot of adapters and weight on an oil pressure line. You should use steel fittings. Long adapters and brass can crack due to vibration.
| The Following 2 Users Say Thank You to Grady For This Useful Post: | DarkPira7e (05-21-2022), fminicooper (05-22-2022) |
#14 |
Drives: 2014 scion frs
I ran my oil pressure sensor on a whip from the top oil gallery and used a pivot dual gauge reporting from the OBD for oil temp.
| The Following 2 Users Say Thank You to 7 skulls For This Useful Post: | fminicooper (05-22-2022), TheBoss77 (05-21-2022) |
| Searching For a replacement USB port for the factory port for aftermarket radio | Kutanks | Electronics | Audio | NAV | Infotainment | 20 | 08-21-2021 09:12 PM |
| Factory oil pressure switch | Cubix | Engine, Exhaust, Transmission | 7 | 08-18-2019 12:36 AM |
| Switch to 5w30 has made my pressure gauge crazy | BDotG | Engine, Exhaust, Transmission | 20 | 05-05-2016 12:52 PM |
| Eliminate oil pressure switch? | @Art_Mighty | Engine, Exhaust, Transmission | 13 | 09-17-2015 10:23 PM |
| FS: Unichip, USB cable, 2 tune selector switch, Clutch switch | BII302 | Engine, Exhaust, Bolt-Ons | 6 | 04-13-2015 08:06 PM |
