Old 03-23-2022, 04:03 PM   #1
radroach
Drives: car
How do I change the front sway bar bushings?
To start, really surprised there aren't any tutorial threads about this 10 years into the car's life. I think I've run into more difficulty on this than I expected - I thought this would be a quick 10 minute job but..
I have taken the wheels off and removed the plastic cover near the front sway bar, and notice that I don't have any room to undo the bolts on the sway bar bushings. How do I change out the front sway bar bushings? Do I have to undo the entire sway bar from the subframe as if I were following a tutorial install for an aftermarket sway bar?
Old 03-23-2022, 04:26 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
It’s really easy, you just remove the bracket that holds the sway bar bracket on. It’s 2x2 bolts per side.
The Following 3 Users Say Thank You to Yoshoobaroo For This Useful Post:
Ohio Enthusiast (03-23-2022), radroach (03-23-2022), whataboutbob (03-24-2022)
Old 03-23-2022, 05:06 PM   #3
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
https://www.ft86club.com/forums/showthread.php?t=39003
BigTuna is offline   Reply With Quote
The Following User Says Thank You to BigTuna For This Useful Post:
Old 03-23-2022, 06:36 PM   #4
Ohio Enthusiast
Drives: 2018 BRZ
I replaced the bushings on both sway bars. The rears are a 10 minute job. For the fronts the bar needs to come out of the car entirely, which is quite the pain with all the panels that need to be removed for that, but otherwise fairly simple.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post:
Old 03-30-2022, 09:47 AM   #5
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
here is a video of how i did it
It's the Little Things - Sway Bar Bushings Capt Spaulding Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 01-28-2021 03:35 PM
Trd sway bar bushings? islandguy69 Issues | Warranty | Recalls / TSB 3 09-30-2017 02:18 PM
TRD Sway Bushings Sweet Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-26-2017 07:34 AM
Is the front sway bar bushings liquid filled? Rayme Issues | Warranty | Recalls / TSB 13 10-02-2014 06:06 PM
Urethane Sway Bar Bushings? phm14 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 01-16-2013 11:32 PM
