Old 02-07-2022, 10:40 PM   #1
uDasBoot
Occasional misfire and Clacking/clicking sound.
So, I just purchased a turboed 2013 FR-S with 80k miles. I've noticed on cold-starts and at idle an occasional misfire. It happens once and only once around every 1.5-2 minutes. I also started hearing what seems like a clacking/ticking/clicking sound coming from a cylinder after it idles down . (On cold start idles around 2500 then calms to 950 after about a minute, not sure if this is stock, or a tuning thing). While messing around with me P3 gauge, and clearing the codes (there were none stored or active before I did this), I noticed the sound go away and then come back 30 seconds later. As you can probably tell, I don't know a ton about this car, especially with the aftermarket turbo kit (Avo turbo kit). I do know it's limited to about 8 psi of boost at max, and that its fun to drive. Any suggestions on what this could be? I'm thinking maybe a fuel injector going bad? I do also know the valve spring recall hasn't been performed yet, could it be an indicator of a spring going bad? Tomorrow morning I will take a video and post the sound, if I can post videos, I'm also fairly new to this forum.
uDasBoot is offline   Reply With Quote
Old 02-07-2022, 11:46 PM   #2
Welcome! A sound clip makes all the difference for these discussions. Is it an automatic? Don't worry. We may tease but it's all in fun. They're great.
Old 02-07-2022, 11:55 PM   #3
uDasBoot
It's a 6 speed manual
Old 02-08-2022, 01:09 AM   #4
Then we can rule out the vacuum pump.
Old 02-08-2022, 03:39 AM   #5
tomm.brz
Drives: brz 2017 hksv2
how is the misfire count when it happens on log?
Old 02-08-2022, 03:03 PM   #6
uDasBoot
I've think I've figured it out. It appears to be the high pressure fuel pump noise that is common on these cars? I will still post a video of the sound in just a minute, but from the videos I've heard of this noise, this is what it seems to be.
Old 02-08-2022, 03:26 PM   #7
uDasBoot
Well, it might not be the hpfp after all. There is a faint chirping, but more of a ticking.
Not sure if it's from YouTube, but the sound isn't as deep, its more ticking then clacking, if that makes sense. It does kind of sound like lifter tick, but as I said, it's not constant, which leads me to believe this isn't lifter tick.
The Following User Says Thank You to uDasBoot For This Useful Post:
Ultramaroon (02-08-2022)
Old 02-08-2022, 04:15 PM   #8
From a warm start, after a few seconds you can expect it to switch over from PI to DI. Once recognized, the sound is obvious.
edit: whoop. Just saw your vid. Yes, that's DI in action. Normal.
tomm.brz (02-08-2022)
Old 02-08-2022, 07:03 PM   #9
uDasBoot
Sheesh, so if that's normal, is there any way to quiet it down? Or just live with it?
Old 02-08-2022, 07:10 PM   #10
lolol...
I think it's a matter of perspective. My wife's C300 is only a little bit quieter because it's stuffed with gobs of fiberglass, or whatever. As long as I know what it is, I'm fine with it. Makes it unique.
soundman98 (02-08-2022)
Old 02-08-2022, 09:12 PM   #11
uDasBoot
Okay thanks, and random question, how do you do that like "Thank You" thing? I can't find the button for it or how it's done,
Old 02-08-2022, 09:59 PM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I believe it appears after your 10th post.
Which you just did.
The Following User Says Thank You to x808drifter For This Useful Post:
uDasBoot (02-09-2022)
Clicking sound above 2k RPM - helpppp slyphen Issues | Warranty | Recalls / TSB 6 09-10-2019 09:11 PM
Clicking sound on startup radroach Issues | Warranty | Recalls / TSB 2 01-17-2019 07:55 PM
FRS Clicking/Tapping sound DCStorm Issues | Warranty | Recalls / TSB 30 12-29-2017 10:59 AM
clicking sound? FR-Sky Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 11-26-2016 10:21 PM
Clicking sound when shifting into 4th? Marcbrz86 BRZ First-Gen (2012+) — General Topics 4 05-19-2015 09:52 PM
