Old 02-04-2022, 09:36 PM   #1
Jynx
Drives: 2013 Subaru BRZ
Having trouble with code u0155
hey guys i have a 2013 BRZ with about 129k miles on it and i am having some troubles with the u0155 code. What happens is i dont get the code if i dont use cruise control or sport mode. if i turn on cruise control, it will work for about 5 mins and then the car will just freak out and go into limp mode and i cannot turn off cruise control and i get and engine light with the code u0155. the cruise control light will stay orange until i unplug the battery. it also happens when i put the car in sports mode. what will happen there is i put it into sport mode and after about ten mins, limp mode and engine light again with code u0155. my question is has anyone had this issue? could it be a bad wiring harness? maybe a bad ecu? grounding issue? where should i start to figure this out? thanks fellas.
Jynx is offline   Reply With Quote
Old 02-05-2022, 12:22 AM   #2
tomm.brz
Drives: brz 2017 hksv2
do you have something obd2 connected?
probably is that, and if yes, you need a better quality device
Old 02-05-2022, 11:47 AM   #3
sato
sato's Avatar
Drives: Dodge Patitas
I had a similar problem (can't remember code) but went away once I disconnected the OBD2 device. Like the other person said, it might be related.
IMO, leave the OBD2 device disconnected when not in use.
Sent from my Pixel 3 using Tapatalk
sato is offline   Reply With Quote
Old 02-05-2022, 03:45 PM   #4
Jynx
i wish that was the issue but absolutely nothing is connected to my obd2 port.
-_-
Old 02-05-2022, 03:57 PM   #5
Jynx
I've checked the battery and the obd2 reader, all good and nothing Bluetooth is connected.
Old 02-05-2022, 04:00 PM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
really really stupid long shot, but if have you checked that all the brake lights work? had a car that would disable cruise if the brake filaments burned out, or had led bulbs/housings installed without load balancers.
Old 02-05-2022, 04:06 PM   #7
Jynx
if my light bulbs are burnt out in the back? If so no, they are all good. I changed my lights in the front and i haven't tried cruise control or sport again because its a bitch when i dont have a 10mm on me lol
Old 02-05-2022, 04:12 PM   #8
soundman98
soundman98's Avatar
the only other thing i can think of that would be related to both sport mode(the paddles) and cruise control could be the clock spring wiring.
easiest step there might be to trace down and disconnect that clock spring connector and see if the problem continues
Old 02-05-2022, 04:28 PM   #9
sato
sato's Avatar
-_-
Old 02-05-2022, 04:29 PM   #10
Jynx
but don't they only go bad if the airbag deployed?
Old 02-05-2022, 08:49 PM   #11
Jynx
well boys, i just tried it again and now i cant get the engine light and the cruise control works lol, this is the first time it has worked in awhile. all i did was push all the wires in under the steering wheel to make sure they weren't lose
The Following User Says Thank You to Jynx For This Useful Post:
soundman98 (02-05-2022)
Old 02-06-2022, 12:30 PM   #12
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
You're right, parts never ever fail in unintended ways, ever.
It's not even irregular to see one fail, happens pretty often regardless of make and model
Old 02-06-2022, 03:17 PM   #13
Jynx
hmm okay, ill watch it for now because magically its working again and i can't get it to kick out the engine light. if it happens again ill make sure to check if it kicks out any other codes along with u0155.
Old 02-06-2022, 03:41 PM   #14
soundman98
soundman98's Avatar
sounds like something wasn't making a good connection in that wiring you pushed on.
issues
P0021 OBD-II Trouble Code: Camshaft Position A - Timing Over-Advanced kingaron06 Engine, Exhaust, Transmission 4 12-11-2018 04:08 AM
P0021 OBD-II Trouble Code: Camshaft Position A - Timing Over-Advanced kingaron06 Issues | Warranty | Recalls / TSB 2 12-11-2018 01:40 AM
Code P0351 Trouble shooting? Bahraini86 Issues | Warranty | Recalls / TSB 46 09-10-2017 05:07 PM
Problems updating form ZA1JA01G to ZA1JD00G ROM - fixed disable U0155 code in rom steve99 Software Tuning 38 09-03-2014 07:44 PM
U0115 OBD trouble code vtmike Issues | Warranty | Recalls / TSB 4 08-31-2013 02:24 PM
