Old 05-23-2020, 04:09 AM   #253
soundman98
ProCrastinationConsultant
soundman98's Avatar
Put a block of wood on the axle shaft and swing harder?
Old 05-24-2020, 02:20 AM   #254
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Alright, both axle nuts are off, but for fuck's sake, the axle will not separate from my hub. Took a mallet, no luck. Does not seem to budge at all. Do I just need to use more force? Take a big chisel to it?
Sensor is off, hub bolts off, etc, unless I'm missing something really simple. Don't want to give up on this as I don't want to pay a shop to do the rears.
Any suggestions?
Now that these cars are old... hammers/air hammers and pointed tools. Took me like 2 hours to do one side of my 2013 frs recently. Had to remove all the e brake bits and airhammer it apart.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 05-24-2020, 07:18 AM   #255
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Figured as much; car is four years at this point. I'm gonna assume that bolting the wheel hub back on and removing the axle first won't do me much good?
Old 05-24-2020, 10:41 PM   #256
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Is the hub flapping around loose? If so, yeah bolt it back up so you don't waste energy when you hit the axle.
If you don't have an air hammer put the axle nut back on until it's flush with the end of the axle and hit it with a BFH.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
KR-S (05-25-2020)
Old 06-21-2020, 06:26 PM   #257
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Nineteen pages of great info.
Can anyone confirm that the Vorshlag "65 mm" can be installed in the front without removing the hub from the car?
I’ve replaced two stock studs now with stock. Quick and easy without taking off anything but the wheel.
The 76 ARP are too long, but seem to be “just” too long to go in without removing anything.
I’ll buy a set of Vorshlag "65 mm" to have at the track in case I break more studs. But if the hubs need to come out anyway, I’ll just go with the ARP instead.
Thanks for the information.
Four_wheel_drifts is offline   Reply With Quote
Old 08-06-2020, 10:22 PM   #258
Four_wheel_drifts
Can ARP 76mm long studs be installed in the REAR hubs without removing the hub from the car?
Old 10-23-2020, 04:02 AM   #259
Four_wheel_drifts
Can confirm the the ARP studs can easily be installed on the front once the rotors are removed. The hubs don’t have to be removed from the car.
Still haven’t attempted the rears. That’s what the off (track) season is for.
The Following User Says Thank You to Four_wheel_drifts For This Useful Post:
JohnJuan (10-23-2020)
Old 10-26-2020, 10:56 AM   #260
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I don't think you're getting the rears done with them mounted on the car if the replacement studs are longer than stock. When I replaced my rears (with same size studs) I only had to remove the caliper and rotor, and there was a space around the 4 o'clock position where you could line up the stud you wanted to remove/replace without having to remove any other components from the assembly. Anything longer than a stock one isn't going to have the same convenience.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
The Following User Says Thank You to Overdrive For This Useful Post:
Four_wheel_drifts (10-26-2020)
Old 10-26-2020, 01:40 PM   #261
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yep you have to remove the hub for long studs. I tried on my red FRS for awhile since the hub was rusted in place and didn't found a way around it. That one corner took like 2-3 hours to do, 5 minutes for the stud change, the rest of the time air hammering shit apart...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-26-2020, 01:54 PM   #262
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
You aren't getting 76mm installed with the hub on the car.
You can install 63mm(2.5") on the rears with the hub on.
You will have to cut the nipple at the end of the stud off, then they will slide in.
Old 02-07-2021, 01:54 PM   #263
kambroso
This thread has been incredibly helpful for me in replacing my wheel studs, so I thought I'd share my experience as well.
After several stripped or broken studs, I opted to install OEM length replacements from ARP (part number 100-7727, $32 for a five pack from Summit Racing). I was also weary of hammering on my wheel hubs, whether or not the risk of damage was high, and opted for the ball joint separator tool. I picked up the one from Advance Auto (part number W83022, $25), and it worked swimmingly. I didn't need to modify it at all, and it worked to both remove the studs and reinstall the front ones. I'll include a couple of photos below. I also wanted to disassemble as little as possible, not to be lazy (though I am) but to avoid the hassle of rusted on parts (this car is my daily driver in very snowy & salty winters). So I only removed the wheels, calipers and rotors.
I greased the bolt threads on the ball joint separator, and used a 15/16" wrench to turn it (all by hand, no air tools). Went a little slow, maybe 1-1.5 hours total per wheel, but it went smoothly. When removing the studs I used the wider jaw setting on the tool, and when reinstalling the studs I used the narrower setting. On removal, the stud would make a loud popping sound each time it moved, usually two pops before it was free, and by the last wheel I had almost stopped jumping every time it happened.
Pressing the new studs in on the fronts went fine. The tool didn't fit on the rears, so I did the lug nut and washer method there. I used seven 1/2" washers and a new lug nut. I was concerned about over torquing the studs, so I used my torque wrench set to 89 ftlbs to pull the studs in, and somewhat surprisingly it didn't take a huge amount of force, and the wrench never clicked.
Now hopefully I won't have any more problems with the studs. For me it was always when removing a lug nut. It would start to stick rather than come off smoothly and I immediately knew it was done. If it was due to user error, the only thing I can come up with is that I didn't clean off the threads really well before reinstalling, and perhaps a small bit of metal got lodged in there and tore things up. But I never had to meticulously clean threads on previous cars, so I don't know. But regardless, I'll be cleaning the studs and nuts thoroughly from now on just in case.
kambroso is offline   Reply With Quote
The Following 2 Users Say Thank You to kambroso For This Useful Post:
DocWalt (01-13-2022), jrhudson (05-09-2021)
Old 01-16-2022, 03:47 PM   #264
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I installed Eibach's 10mm extended stud/spacer kit using the balljoint spreader tool method on my 2022 BRZ today. Pretty simple as it is on the first gen or most other cars. Warning though, the 2022+ BRZ with aluminum knuckles uses different torque specs than first gens (now 88.5 ft-lbs for the two caliper bracket/knuckle bolts and 70.1 ft-lbs for the four hub/knuckle bolts) but more annoyingly, the knuckle is in the way and there's no way to install extended studs without pulling the hub. Not a huge deal and overall pretty simple!
The Following 4 Users Say Thank You to DocWalt For This Useful Post:
jongers (01-16-2022), NoHaveMSG (01-21-2022), villainous_frx (01-16-2022), Yoshoobaroo (01-16-2022)
Old 01-21-2022, 03:34 PM   #265
MacSpeed
MacSpeed's Avatar
Drives: 2022 BRZ
If you pull the dust shield, there's enough room on that side to slip the extended studs on the 2022. I was able to do front and rear without pulling any hubs off.
MacSpeed is offline   Reply With Quote
Old 01-21-2022, 04:29 PM   #266
rBobby
Drives: 2022 BRZ
What length studs did you use?
rBobby is offline   Reply With Quote
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 05:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 03:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 11:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 03:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 01:28 PM
